With well over 130 streams available, it became time for a major update of the fully loaded version of the software.
Remember there are two versions of the software available:
For those of you who wish to be able to link to all of those streams from your site, there is the fully loaded version. This is the version with a major update.
The latest version of the current script you can see it in action
here . Jerry gwwilk was very very kind to help consolidate the code to the point that we now have 2 files instead of 3. The code now consists of a main script and an include script. The select file has now been moved into the include script. The code should also be a bit faster with the changes as well. I want to thank Gerry for his efforts, I think my earlier work caused him enough pain that he felt the amount of time spent on the work would reduce the constant need for him to take another antacid whenever he looked at the earlier code.
As before, I have the two files available via ?sce=view. Please note that the include file is constantly updating as we add stations, or if stations change their url, so you may need to download updates of that file from time to time to keep up, but now it is only one file not two. Although for this update you will need to upload the main file as well.
The main file can be downloaded
here and the include file which really does all the work can be downloaded
here . To have the code start on your area weather station change the default callsign on the main page you can also adjust the width of the display at that location.
The current version for the files as of this moment.... is 20170414.
UPDATE: The include file is 20170414A - Found a bug when trying to access the website supplying the feed.For those who only wish to stream their own stream there is the economy version, this one shouldn't require much maintenance as you aren't tracking all of those new streams. This version has a operator defined setup at the top of the page, like its big brother it is designed around the Saratoga template and it is one script rather than 2. You can see it in action
here and it can be downloaded
here . This file as it doesn't have all of those bells and whistles was not updated, much like an old VW bug.
Bob
