Author Topic: Tapatalk error  (Read 1794 times)
Offline leswarden
    • My Davis Weather Station
Tapatalk error
« on: January 07, 2020, 02:38:05 PM »
Brand new member here. First post. After registering, I tried to login using Tapatalk which I use for several forums I follow. Here is a screenshot of the error. I haven’t searched for the issue yet. Is there a simple answer? A plug-in issue? [ You are not allowed to view attachments ]
Offline leswarden
Re: Tapatalk error
« Reply #1 on: January 08, 2020, 06:32:23 PM »
Searching the forums looks like Tapatalk has been used in the past. Based on that, and absolutely no feedback, I’ll assume this is some issue with your website. Difficult to view the website version on an iPhone, but I’m patient while you investigate this error.
KILAUBUR06
FW6606
Re: Tapatalk error
« Reply #2 on: January 08, 2020, 07:55:25 PM »
I've updated the Tapatalk SMF plugin on the forum to the latest version (tapatalk_smf-2a_v4.5.4).  Thanks to some older code in their plugin, I had to add
error_reporting(0); to two sub-functions (Subs.php, Load.php) to staunch a flood of messages in the SMF error log.
Let me know if this update fixes your issue.
Best regards,
Ken
Offline leswarden
Re: Tapatalk error
« Reply #3 on: January 10, 2020, 11:59:35 PM »
It does now allow me to login, although not always consistently. What seems to be in the randomness of operation is this consistent message...if that sentence makes any sense.
Offline Oilswell
Re: Tapatalk error
« Reply #4 on: January 11, 2020, 06:54:35 AM »
My experience with Tapatalk is terrible in this forum. Loading times are unbearable so I end up reading forums via Android browsers which is definately much more difficult to read from due to formatting but at least loading times are reasonable.
Re: Tapatalk error
« Reply #5 on: January 11, 2020, 10:08:35 AM »
Sorry about that!  I'll see what I can do about the Tapatalk access/functionality later today after the forum is moved to new hosting.
Re: Tapatalk error
« Reply #6 on: January 11, 2020, 03:52:56 PM »
Tapatalk plugin updated to Version 4.5.7.  Hopefully this will fix those pesky issues.
Offline Oilswell
Re: Tapatalk error
« Reply #7 on: January 11, 2020, 05:06:45 PM »
I hope you didn't take that personally as it wasn't meant to be a dig. I just mentioned it because I thought it was a Tapatalk problem.
Re: Tapatalk error
« Reply #8 on: January 11, 2020, 05:20:15 PM »
No offense taken... the code for the tapatalk plugin is quite messy and was casting a lot of Deprecated errors in the log (until I put in error_reporting(0); in several places to shut off the flood).
Is it working better with the updated plugin on the new VPS host?
Offline Oilswell
Re: Tapatalk error
« Reply #9 on: January 11, 2020, 05:47:02 PM »
Sorry to say this but I don't think it worked...
Sent from my SM-N960W using Tapatalk
Re: Tapatalk error
« Reply #10 on: January 11, 2020, 05:55:50 PM »
What is/are the failure(s) you're seeing?  Was your above message posted via Tapatalk (as the 'Sent from my SM-N960W using Tapatalk' indicates)?
Offline leswarden
Tapatalk error
« Reply #11 on: January 11, 2020, 06:01:19 PM »
I’m seeing some extended time when accessing a forum thru Tapatalk. Doesn’t necessarily equate to an error.
« Last Edit: January 11, 2020, 06:03:19 PM by leswarden »
Re: Tapatalk error
« Reply #12 on: January 11, 2020, 06:06:07 PM »
Me too.  I fear it is a Tapatalk issue. Direct access to the forum is quite responsive. I’ll check with Tapatalk support.
Offline Oilswell
Re: Tapatalk error
« Reply #13 on: January 11, 2020, 06:34:38 PM »
This is the same I'm experiencing, very long load times but no errors.
Offline sjbauer
Re: Tapatalk error
« Reply #14 on: January 11, 2020, 07:10:15 PM »
When I was scrolling through my unread posts I got this when it was taking a long time to load more messages.
Sent from my Moto G (5) Plus using Tapatalk
