What I would try first, is pop off the bottom of the radiation shield, (part with holes) then use the two side tabs to take out the temp sensor section. This will get you to the fan blade. Next, pull the fan blade off by pulling straight out with pliers. It isn't on real tight, so no need to be rough with it. Next oil the motor by turning everything upside down and let the oil get in around the stem of the motor. If this doens't fix it, which I think it will, you will need to take the whole thing apart to replace the motor.
