Author Topic: Meteobridge offset not showing in WLL.  (Read 776 times)
Offline dj1111s
  • Weather obsessed
  • The "d" cloud.
« on: March 10, 2021, 09:23:46 PM »
I recently had to replace my Vantage Pro 2 outside temperature/humidity sensor. The humidity sensor failed. Per the instructions for the new sensor (used in my older Sensor Suite) I included a -.9 degree offset for the main outside temperature (th0temp) in Meteobridge settings. I’m uploading to PWS, Ambient, WU and Weatherlink Live (Nooo it's Weatherlink Cloud  #-o). The -.9 temperature offset is displaying correct for all of the above networks except Weatherlink Live. It is not getting the offset.
Does anyone know of a fix for this?
« Last Edit: March 11, 2021, 05:12:07 PM by dj1111s »
Vantage Pro2 Plus W/FARS, wireless anemometer, bucket heater with temperature sensor. Envoy, VP2 and Vue consoles. Meteobridge. Weatherlink Live. AirLink. Soil and leaf station. Attic temp and humidity.
Trained Storm Spotter
Member CoCoRaHS
You will never find me on Facebook or Twitter or any other social media!!!
Offline mcrossley
    • Wilmslow Astro
Re: Meteobridge offset not showing in WLL.
« Reply #1 on: March 11, 2021, 03:05:34 AM »
 The WLL is the source of data it sends to other receivers of data. Unless you have a mb pro that you have configured to directly receive the ISS transmissions?
But you should set the offset in the ISS advanced settings for your WLL either on WeatherLink.com or in the WL phone app.
Offline dj1111s
  • Weather obsessed
  • The "d" cloud.
« Reply #2 on: March 11, 2021, 09:41:24 AM »
Sorry mcrossley I need to get my wording right. It's not WLL that I'm using. I'm uploading to WL Cloud through my Meteobridge. The offset is in Meteobridge. The -.9 temperature offset is displaying correct for three networks I'm uploading to but not www.weatherlink.com/bulletin...
Member CoCoRaHS
Offline mcrossley
    • Wilmslow Astro
« Reply #3 on: March 11, 2021, 09:48:21 AM »
Davis use WeatherLink for far too many different things!
Offline TraderGary
  • Stock Market Wizard
  • Amateur Radio W9VJ
« Reply #4 on: March 11, 2021, 11:16:28 AM »
I agree. I'm still relatively new to weather stations and I purchased the Davis WeatherLink Live 6100. It took a while reading the forums to understand that I was confusing comments about older Davis WeatherLink software with my physical Davis WeatherLink Live 6100 device.
Davis Vantage Pro2 Plus 6163 (Wireless) | Davis WeatherLink Live 6100 | Meteobridge Pro
WeatherLink | WundergroundCWOPAWEKASWindy
« Reply #5 on: March 11, 2021, 11:27:34 AM »
You need to do the following two steps.
1- Undo the temperature correction in the Meteobridge.
2- Go to your display console and in there set the temperature offset. You can find the instructions to do this on page 26 of the Davis user manual.
From the Davis VP2 console user manual:
Calibrating, Setting, and Clearing Variables
To fine-tune your station, you can calibrate most of the weather variables. For
example, if your outside temperature seems consistently too high or too low, you
can enter an offset to correct the deviation.
Calibrating Temperature And Humidity
You can calibrate inside & outside temperature, inside & outside humidity, as well
as any extra temperature/humidity sensor readings you have transmitting to your
Vantage Pro2.
1. Select a variable to be calibrated. See “Selecting Weather Variables” on
page 20.
2. Press and release 2ND, then press and hold SET.
After a moment, the variable you’ve selected begins to
blink. Keep holding SET until the Calibration Offset
message displays in the ticker.
The ticker displays the current calibration offset.
3. Press the+ and - keys to add or subtract from the temperature offset value.
Inside and outside temperature are calibrated in 0.1° F or 0.1° C increments,
up to a maximum offset of +12.7 (°F or °C) and a minimum offset of -12.8 (°F
or °C). The variable will change value and the ticker will show the offset
you’ve entered.
4. Press DONE to exit calibration.
« Last Edit: March 11, 2021, 11:29:12 AM by galfert »
Offline dj1111s
  • Weather obsessed
  • The "d" cloud.
« Reply #6 on: March 11, 2021, 02:24:14 PM »
I have two consoles around the house that I already applied the offset to.
The logger supplying data to my Meteobridge is in a wireless Weather Envoy not a console. Is there a way to get into the Envoy to make changes? Would the Envoy have to be connected to a computer to do this, if it’s possible?
« Last Edit: March 11, 2021, 02:26:36 PM by dj1111s »
Member CoCoRaHS
« Reply #7 on: March 11, 2021, 04:38:29 PM »
You'll need to install Weatherlink for Windows to then configure the Envoy. You can temporarily disconnect the Meteobridge from the Envoy to accomplish this.
Page 18 (Set Temp & Hum Cal):
https://www.davisinstruments.com/product_documents/weather/manuals/envoy_manual%20test.pdf
Offline dj1111s
  • Weather obsessed
  • The "d" cloud.
« Reply #8 on: March 11, 2021, 05:10:29 PM »
Thank you galfert. I already have Weatherlink on my computer just haven't used it since installing the Meteobridge.
It's all coming back to me now. [tup] Had that computer on 24/7 for Weatherlink for many years.
Member CoCoRaHS
