Author Topic: Vantage Pro 2 losing connectivity with PC  (Read 1870 times)
Offline Peterbilt 1979
« on: November 30, 2024, 12:43:46 PM »
Hi all I have been uploading to Weather Link for a number of years ,but lately my console loses connectivity with Weatherlink program  ,PC is set to never go in sleep mode ,also console is on a battery backup plus I have fresh batteries in as well ,it is cabled with USB and all I have to do is unplug and plug back in to get it back online .it is also occurring sporadically sometime it will stay on days at a time and sometimes only a few hours. anyone ever run across this issue .
Re: Vantage Pro 2 losing connectivity with PC
« Reply #1 on: November 30, 2024, 02:38:31 PM »
Being that its a direct connection to the PC that's a tough one.
Just a suggestion but what about updating the drivers on your USB connection. I seem to remember a long time ago when I used to do that the drivers had to be updated regularly.
Also it may be a software issue. WL isn't exactly cutting edge technology. Maybe try one one of the other software programs like Cumulus or Weather Display and see if the issue continues.
Offline zeppline
    • Las Vegas Weather Guy
« Reply #2 on: November 30, 2024, 02:46:34 PM »
You can look at the device manger, universal serial bus controllers, look for your USB port (I think it is 3) and double click on it and check the power management and uncheck allow the computer to turn off this device.
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #3 on: November 30, 2024, 03:28:57 PM »
By losing connection,  do you mean the bulletin mode just closes ? Or do the charts just stop updating ?
Offline Mattk
« Reply #4 on: November 30, 2024, 03:35:58 PM »
Would be looking at the computer and drivers.
« Reply #5 on: November 30, 2024, 03:40:18 PM »
I checked device manager and it was check marked to turn station of to save power ,hopefully it will solve problem .Thank you all for the responses
« Reply #6 on: November 30, 2024, 03:47:49 PM »
BTW if I were to switch to Cumulus ,would  I still use the dongle that is plugged into the  Vantage Pro 2 display ?
Offline PaulMy
« Reply #7 on: November 30, 2024, 04:20:39 PM »
Yes, the logger is needed.
For first time CumulusMX running with the station, after you start CumulusMX follow the instructions ro run the Config Wizzard.
For Station settings > Station Type > select Vantage Pro 2 >
Davis VP/VP2/Vue > Davis Connection Settings > Connection Type: Serial (unless you have the IPlogger) > Serial Port Name > enter your PC's Com port.
Enjoy,
