Author Topic: Is current WD download bad?  (Read 2222 times)
Offline broadstairs
« on: August 05, 2022, 02:53:22 PM »
There are some reports on the WD forum which suggest the 4th July WD installer is corrupt. Has any one here had issues with it?
Stuart
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
Re: Is current WD download bad?
« Reply #1 on: August 05, 2022, 03:44:45 PM »
I tried earlier today to install for purpose of testing for a question and I had it give "File Corrupted" error and install failed. I downloaded three times.
Offline broadstairs
« Reply #2 on: August 05, 2022, 04:14:14 PM »
Good to know, I looked at the current download and was concerned that it was significantly smaller than previous files and as I said some others have issues with it.
Stuart
Just looked at the downloads and there is a new one today 5th July which looks normal size so hopefully is OK. I made an opps there. Anyway today 6th August there is a version from the 5th August which is 206mb so hopefully that one is OK.
« Last Edit: August 06, 2022, 12:05:11 PM by broadstairs »
Offline swright1957
    • Wakefield Way PWS
« Reply #3 on: August 06, 2022, 12:01:48 PM »
Hi all
I downloaded the latest update and unzipped it (580mb) installed it and no problems so far.
Strange that..
Steve
"anything's possible with the weather"
www.hytheweather.co.uk/signaturebanner.gif
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #4 on: August 06, 2022, 11:26:12 PM »
Interesting. The download that fail3d on me was an install executable, not a zip file.
Offline swright1957
    • Wakefield Way PWS
« Reply #5 on: August 07, 2022, 03:58:22 AM »
Hi
I downloaded the update and unzipped it.
Details below:
Offline swright1957
    • Wakefield Way PWS
« Reply #6 on: August 08, 2022, 08:22:46 AM »
Hi
there is a new download to install...
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #7 on: August 08, 2022, 03:17:16 PM »
.... 4th July WD installer is corrupt....
..... install executable ....
The Install File Download is working fine here now.
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #8 on: August 08, 2022, 07:33:29 PM »
Is the main screen the same old one ? Or is it better? I have considered giving up on it because it is hard to read and the graphs on the right side eat up too much space. I know lots use it because of it being a "Swiss Army Knife" but I get a better view of conditions from VWS or WX Solutions on my local screen. Is there a way to modify the main screen of WD to make it easier to read ? I have tried the settings but still end up with those huge graphs.
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #9 on: August 08, 2022, 11:28:50 PM »
I haven't had a look at it fired up yet. Will try it out to see how it looks on new wide-screen.
Offline swright1957
    • Wakefield Way PWS
« Reply #10 on: August 09, 2022, 09:52:03 AM »
Hi
if you go into the file>advanced/Misc settings > Main screen customize,  there is an option to move the main screen details around.  I agree I dont like the graphs so I have moved, so i have moved them all out of the way to a really small box that i just ignore..
Offline Garth Bock
« Reply #11 on: August 09, 2022, 10:31:48 PM »
Hi
Thanks I will try that. I hear complaints about how "dated" Weatherlink looks but WD seems to be looking old too. The info is hard to read without going in and changing colors and fonts. Would be nice if the main panel were redesigned and cleaned up.
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« Reply #12 on: August 15, 2022, 01:43:13 AM »
The main screen is very customizable, it can take quite some time to get it how you want it mind but once done there shouldn't be a need to touch it again, mines been like this (see image) for the last hundred years, give or take ;)
« Last Edit: August 15, 2022, 01:49:38 AM by Bashy »
Kind regards
Bashy
Offline swright1957
    • Wakefield Way PWS
« Reply #13 on: August 15, 2022, 03:10:41 AM »
Hi bashy
Very nice screen layout.
Mines getting there, just always tweaking it and adding more info.
Steve
Offline broadstairs
« Reply #14 on: August 15, 2022, 04:26:51 AM »
This is getting rather off topic so might be worth a mod splitting off the screen customisation to a separate thread so folks could find it more easily!
Stuart
