Wxtech is correct. Many compressors have contaminants in their air discharge. Best to use canned air if uncertain, but that doesn't have the capacity of your compressor, of course.
I also do as Andrew suggests, but I use a HEPA vac to capture all that tiny, minute stuff.
It's amazing how much accumulates, in a short period of time, inside the PC.
Another good hint is to install filters on your intake fans.
They're small and resemble the same media as an air conditioner foam filter. And you can get a clip on bracket that holds the media on the face of the fan.
They save the bearings on the PC fans, and you can simply rinse the filter in the sink and air dry it when it gets dirty.
No matter what you try, dust will accumulate eventually inside the PC, but routine maintenance is important.
I have to vacuum away the accumulations on the radiators of my water cooled PC's quite often, and I monitor the temperature to alert me it's time to clean.
Good luck...have fun too.
