Author Topic: Setup new server help  (Read 618 times)
Offline Bashy
  • brecklandweather.com/meteo
    • Breckland Weather
« on: June 18, 2020, 12:49:37 PM »
Hi folks, just got a new server as my old onw is running centos6 and i need 7, anyhoo, its just a cheap kimsufi jobby so you get no management, same as the server i already have.
The issue i am having is, not knowing what i am doing and cannot remember what i did to get the old one running, been a few years now. You would think it would be simple,  get a server, they send email with the details, password etc, nothing of the sort, you have to netboot into emergency mode, that then sends you a temp root password that takes you into root@rescue:~# prompt.
The instructions ive read on the useless kimsufi forum dont make any sense to me, it says you can then # passwd root to change the password, done this many times and it just says the password is denied when i try to login to normal ssh, at me wits end with it now.
Heres the instructions, but, a lot of that does not resmble what i am seeing
when i fdisk in, i get
root@rescue:~# fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: FE06FC53-9BA5-44A0-A75F-DAD5337A4534
Device          Start        End    Sectors    Size Type
/dev/sda1          40       2048       2009 1004.5K BIOS boot
/dev/sda2        4096    2099199    2095104   1023M Linux filesystem
/dev/sda3     2099200 3904925695 3902826496    1.8T Linux filesystem
/dev/sda4  3904925696 3907020799    2095104   1023M Linux swap
Am i to assume ive already mounted the drive, i thought thats what i did when i loaded the software  :???:
I really hope theres someone in the know, cause i sure aint, im sure it wasnt this difficult with the existing kimsufi server  ](*,)
Kind regards
Bashy
