Author Topic: Stationary model of the solar system  (Read 6532 times)
Offline Fermer05
  • Moderated Member
« on: February 22, 2020, 11:16:56 AM »
Stationary model of the solar system.
Community of Russian scientists. https://vk.com/rosuch
1. The solar system is an autonomous object of the Universe, does not rotate around the center of the galaxy, but is in a stationary state in space.
2. In the infinite Universe there is a solar system, in the center of which the Sun rotates, emitting light.
As sunlight moves toward the edge of the solar system, the kinetic energy of light is converted into potential energy, causing the speed of light to decrease.
Approaching the edge of the Solar System, under the influence of the Coriolis force, sunlight is deflected and begins to move along the perimeter of the Solar System, against the rotation of the Sun.
3. Next, the light, moving along the edge of the Solar system, collapses into a star, due to which the kinetic energy of light is transformed into the rotational energy of stars. https://fr.wikipedia.org/wiki/%C3%89tat_plasma
At the edge of the Solar System, the mass of stars, the force of gravity, the speed of light, as well as the axial and orbital speed of stars are close to zero.
4. The star, being in a state of "weightlessness", floats along the edge of the Solar system in the form of plasma, nebulae and galaxies in the direction of the rotation of the Sun, relying on the laws of celestial mechanics and temperature differences - the Yarkovsky effect. https://en.wikipedia.org/wiki/Yarkovsky_effect
A nebula is formed as a result of the explosion of a star that has reached critical mass and consists of gas and dust. https://en.m.wikipedia.org/wiki/Nebula
The galaxy is a lenticular nebula formed as a result of the explosion of a rotating star. https://en.m.wikipedia.org/wiki/Stellar_rotation
5. Approaching the Sun, the star becomes denser, due to which the temperature and brightness of the stars increases, nebulae, galaxies and asteroids are formed.
Most of the mass of the Solar System is accounted for by the Sun and the ecliptic plane, due to which asteroids, revolving around the Sun, slowly approach both the Sun and the ecliptic plane, due to which the Kuiper belt is formed.
Then planets emerge from the Kuiper belt, surrounded by a system of rings from which satellites are formed. https://youtu.be/0iaOnql4d3E?si=h4CwWv5zLxY9WoBl
6. Further, as they approach the Sun, the temperature, axial and orbital speed of the planets and satellites increase, due to which the satellites are thrown out of orbit and the planets are overturned. https://youtu.be/QaO9gC9EXNI?si=rOzRc9TaFdQGpHDb
When the planet comes close to the Sun, the geological activity of the planets increases, resulting in an explosion of the combustible mixture in the fractures of the planets, and as a result the planet is destroyed into fragments, similar to Comet Shoemaker - Levy 9.
Then fragments of the planets, rotating around the Sun at a speed of tens of km/sec, crash into the surface of the Sun, due to which the axial speed of the Sun increases. The self-ignition temperature of gases is about 500 degrees.
7. The radius of the Solar system depends on the speed of light, the radius of the Sun, and the axial velocity of the Sun. R ≈ c•r/ω.
The speed of light is ≈ 1,000,000,000 km/hour.
The radius of the Sun is ≈ 700,000 km.
The linear rotation speed of the Sun is ≈ 7000 km/h.
The radius of the Solar system is ≈ 1,000,000,000,000 km.
Due to the Coriolis force of the Sun, the Solar system is not scattered in space, but has the shape of a sphere.
8. Sunlight, rotating along the edge of the solar system, collapses into a star, due to which the kinetic energy of light is transformed into the rotational energy of stars, according to the following scheme.
a) When a photon moves against the rotation of the Sun, the centrifugal force of the photon decreases, due to which the photon begins to move closer to the Sun.
b) When a photon approaches the Sun, the Coriolis force deflects the photon in the direction of the Sun's rotation.
c) When a photon moves towards the rotation of the Sun, the centrifugal force of the photon increases, causing the photon to move away from the Sun.
9. The Earth and Moon pair, in an elliptical orbit, rotate around a common center of mass and move in the direction of rotation of the Sun.
A photon consists of two particles rotating around the center of mass, which move in space against the rotation of the Sun, thanks to the deflecting Coriolis force of the Sun.
https://en.m.wikipedia.org/wiki/Light
The photon and the Sun are interconnected by gravity, just like the Sun, Earth and Moon. (Three body problem).
The more the gravity of the Sun affects the particles of the photon, the more the orbit of the particles is extended and the greater the speed of the Photon. https://en.m.wikipedia.org/wiki/Photon
At the edge of the Solar System, as the Sun's gravity decreases, the ellipse of particles also decreases, due to which the speed of Photons decreases significantly.
Next, the photons move from the edge of the Solar System to the Sun in the form of stars, planets and satellites, over billions of years, possessing enormous potential energy, which can be calculated using the following formula. U = (Ms+mch)•r
Ms - Mass of the Sun.
mch - Particle mass.
r - Distance from the Sun to the particle.
Without the gravitational influence of the Sun, the Earth-Moon Pair and Photon disintegrate.
Based on the mechanics of interaction of three bodies, it is possible to construct a supportless propulsion device. https://youtu.be/um5nS-vA9is?si=ORVhOM36rKW2PcKZ And its transformations. https://youtu.be/4_M-fBv5Xmc?si=3nRFzsUytTQDqqvb
10. An asteroid is born as a result of the explosion of a star that has reached critical mass, and is accompanied by the release of gas and dust. https://en.m.wikipedia.org/wiki/Supernova
Next, a nebula is formed from gas and dust, and then a galaxy, similar to cyclones and anticyclones. https://en.m.wikipedia.org/wiki/Galaxy
The size, shape, axial tilt, and rotation rate of a galaxy depend on the axial velocity of the star before the explosion. https://en.m.wikipedia.org/wiki/Stellar_rotation
Galaxy without stars. https://www.nytimes.com/2024/01/26/science/space/dark-galaxy-stars.html
11. Proper motion of stars.
https://en.m.wikipedia.org/wiki/Proper_motion
Galaxies, atmospheric cyclones and anticyclones rotate around their own axis and in orbit, and everything that rotates has the property of a gyroscope to maintain the vertical position of the axis in space regardless of the rotation of the Earth, due to which blocking, overturning and drift of galaxies occurs.
The direction of galaxy drift depends on the inclination of the axis and orbit of the galaxies relative to the ecliptic plane.
Due to the gyroscope properties that galaxies have, galaxies drift around the entire perimeter of the Solar System rather than aligning themselves in the ecliptic plane. https://youtu.be/aj-RClXNloc?si=AK_KmsP1X9tcl0Hz
Perhaps Barnard's flying star revolves around the Sun in a highly elongated orbit and is at perihelion.
Or Barnard's Star, this is a dwarf planet that revolves around the Sun in a highly elongated orbit with an orbital period of more than 1000 years and is at aphelion.
The speed of Comet Halley at perihelion is 54 km/s, and at aphelion 1 km/s. https://www.google.com/amp/s/spacegid.com/zvezda-barnarda.html/amp https://kosmolenta.com/index.php/1710-2021-02-12-farfarout
12. Outside the solar system, sunlight does not penetrate and it will be impossible to see the solar system from the side of the universe.
13. So little sunlight comes to Pluto that our star can be confused with a large star. Sunlight on Pluto is thought to be 1,600 times dimmer than on Earth. https://safereactor.cc/post/2769840
14. Perhaps the star reflects both its own light and the Sun?s light.
a) What has been said can be easily verified by performing a simple experiment.
15. Our Sun loses more than 1 billion tons of matter per year due to the emission of light.
I assume the same amount of matter falls onto the Sun from space.
The assertion that the solar system revolves around the center of the Galaxy does not stand up to criticism.
If the Solar System revolved around the center of the Galaxy, then the Earth, rotating around the Sun, would approach and move away from the center of the Galaxy, as a result of which the Earth’s orbit, thanks to the Coriolis force of the Sun, would be elongated along the orbit of the Sun. Similar to the lunar orbit. https://en.m.wikipedia.org/wiki/Galactic_year https://en.m.wikipedia.org/wiki/Milky_Way
But the orbits of the planets are not elongated along the “orbit of the Sun”, this means that the Sun does not rotate around the center of the galaxy but is stationary in space. https://m.habr.com/ru/post/411567
Objects in the Solar System cannot endlessly rotate around numerous centers.
The laws of celestial mechanics are not omnipotent and are limited to the three-body problem; the Earth revolves around the Sun, the Moon revolves around the Earth, and nothing revolves around the Moon.
No natural satellite of the planets has a permanent or temporary companion, as this would already be a four-body problem, which is contrary to the laws of being.
For this reason, the artificial satellites of the Earth rotate by inertia much longer than the artificial satellites of the Moon. https://naked-science.ru/qa/518331
And the most important question is why asteroids have satellites, but planetary satellites do not have satellites, despite the fact that planetary satellites are much more massive than asteroids. https://en.m.wikipedia.org/wiki/Subsatellite
Saturn's two moons, Janus and Epimetheus, move in the same orbit and pass each other every four years. If these two satellites orbited the Sun, then Janus would have captured Epimetheus. https://elementy.ru/kartinka_dnya/430/Tanet...usa_i_Epimetey
In nature there is no relationship without symbiosis, and the solar system does not need the center of the galaxy.
Comet Galya orbits the Sun every 75 years, in a highly elongated orbit, due to the fact that the Sun does not revolve around the center of the Galaxy.
The Big Bang theory was born from the observation that other galaxies are moving away from ours at great speed in all directions, and based on this hypothesis the Big Bang hypothesis was written. https://bigenc.ru/c/teoriia-bol-shogo-vzryva-217844
1. Thanks to what forces the Universe assembles and explodes. Without an answer to this question, the Big Bang hypothesis has no right to exist.
2. After the Big Bang, the Galaxies, having received fantastic kinetic energy, must move in a straight line and forever.
a) Rectilinear motion contradicts the laws of celestial mechanics.
3. The center of the Solar system is the Sun, and the role of the Sun for the Solar system is vital, but what role does the center of the Universe play for the Universe,  what is there and what happens?
4. What was the state of the laws of celestial mechanics before the explosion, at the moment of the explosion, and after the explosion, how and when did they arise?
5. Moving away from the center of the Universe, the galaxies began to rotate around their own center, what force rotates the galaxies and where did this force come from?
6. After expansion, the Universe contracts back and Galaxies rush towards the center of the Universe with enormous speed.
7. For what reason the galaxies stopped scattering and began to gather.
8. What force attracts galaxies to the center of the Universe, if it is a gravitational force, then how does it arise?
9. How much energy is released when a galaxy collides with the center of the Universe. https://bigenc.ru/c/singuliarnost-prostranstva-vremeni-867893
10. The statement that the spiral arms, together with the stars, move around the center of the galaxy with the same angular velocity (like helicopter blades) contradicts the laws of celestial mechanics.
At the same time: The farther the planets are from the Sun, the lower the orbital speed of the planets.
While Neptune makes one revolution around the Sun, Mercury makes more than 500 revolutions.
a) The statement that in spiral galaxies a star rotates along with the arms is questionable, for the reason that we see only those stars that are behind the arms and illuminate the arms. https://en.m.wikipedia.org/wiki/Spiral_galaxy
11. An interstellar cloud approximately 30 light years across and with a temperature of about 6,000 degrees is believed to be located in our galaxy. https://en.m.wikipedia.org/wiki/Local_Interstellar_Cloud
At the same time, the Earth, rotating around the Sun and the center of the galaxy, moves through the cloud at a speed of 250 km/sec.
a) Does the Earth encounter interstellar gas and dust as the Earth moves behind the Sun?
b) What changes occur in the atmosphere of planets when planets enter a cloud?
c) Does interstellar gas and dust reduce the orbital speed of planets, satellites and comets?
d) Are there any facts of collisions of artificial satellites with gas and dust molecules?
e) How does a star emit gas and dust molecules, and where is interstellar fog located in the solar system?
f) How does interstellar dust reach each other if the distance between stars is hundreds of light years?
g) If the stars emitted gas and dust, then a continuous fog with zero visibility would hang in the starry sky.
https://bigenc.ru/c/mezhzviozdnyi-gaz-2dc301
The density of interstellar gas can reach 10,000 molecules per cubic centimeter.
https://dic.academic.ru/dic.nsf/ruwiki/1828708
12. The statement that a star emits dust, gas and plasma, and then the dust, gas and plasma turns back into a star, contradicts elementary logic. https://en.m.wikipedia.org/wiki/Stellar_evolution
Coriolis force on Earth and in the Solar System. https://en.m.wikipedia.org/wiki/Coriolis_force
The Coriolis force occurs when an object approaches or moves away from the Earth's axis.
At the same time, when an object that moves on or around the Earth approaches or moves away from the axis of the Sun, the Solar Coriolis force is generated.
The deflecting Solar Coriolis force, due to the axial and orbital rotation of the Earth, is somewhat more complex.
The flow of the Volga River is constantly pressed against the western bank of the river by the Coriolis force of the Earth, and the Solar Coriolis force, due to the axial and orbital rotation of the Earth, deflects the flow of the Volga River either to the western bank or to the eastern bank twice a day. For this reason, winding currents form in the seas and oceans. https://en.m.wikipedia.org/wiki/Meander
The above can be easily verified by rotating a globe around its axis and orbit, entwined along the equator and meridian with a polyethylene hose in which the liquid moves.
The Coriolis effect of the Earth does not depend on the inclination of the axis of the earth, and the Solar Coriolis force depends.
The solar Coriolis force is involved in the formation of the Moon's ellipse.
When the Moon, rotating around the Earth in the last quarter approaches the Sun at a speed of 1 km/sec, and in the first quarter moves away from the Sun at a speed of 1 km/sec, the Solar Coriolis force slightly stretches the Moon's orbit along the Earth's orbit, due to which the Moon's elliptical orbit is formed . https://images.app.goo.gl/wmqRKPc9jzScCrB16
When the Moon is in its new and full moon phases, the Solar Coriolis Force does not affect the Moon's orbit because During these phases, the Moon does not approach or move away from the Sun.
The eccentricity of the Moon's orbit can be calculated using the following formula. E = Vz / Vl = 0.0411 / 0.55 = 0.0747
Where Vz - Earth's orbital speed - 0.0411 degrees / hour.
Vl - Moon's orbital speed - 0.55 degrees / hour.
E = (Vz / Sz) / (Vl / Sl) = 0.00071 / 0.0095 = 0.0747
Where Vz is the Earth's orbital speed - 107,218 km / h.
Sz - Distance from the Sun to the Earth - 150,000,000 km.
Where Vl is the Moon's orbital speed - 3683 km / h.
Sl - Distance from the Earth to the Moon 384,000 km.
The eccentricity of the Moon's orbit varies, from 0.026 to 0.077.
Both formulas show that the average eccentricity of the Moon's orbit is 0.0747.
And the average eccentricity of the moon's orbit, obtained using radar, is 0.054.
Also, the eccentricity of the Moon's orbit can be determined by the following formula. E = Vl / Vz = 27.3 / 365.2 = 0.0747
Where Vl is the Moon's orbital angular velocity.
Vz - Orbital angular velocity of the Earth.
By dividing the orbital speed of the Moon by the eccentricity of the Moon's orbit, the Earth's orbital speed can be calculated. https://en.m.wikipedia.org/wiki/Moon
Based on the fact of the approach and removal of the moon from the sun, it is possible to construct. Reactionless drive. https://youtu.be/4_M-fBv5Xmc
The reason for the geological activity of the planets is also the Coriolis solar force.
The side of the Earth located at dawn, as a result of the axial rotation of the Earth, approaches the Sun at a speed of 1600 km/h, and the side of the Earth located at sunset moves away from the Sun at a speed of 1600 km/h. due to which the Solar Coriolis force stretches the Earth along the Earth’s orbit, and as a result, the geological activity of planets and satellites increases. (Rotating planets heat up, like a flat tire on a car.)
The high geological activity of Jupiter's moon Io can be explained by the fact that the axial and orbital velocity of Io is 15 times greater than that of the Moon.
Io's orbital speed is 17 km / s, and the Moon's orbital speed is 1 km / s. Io's axial velocity is 1 revolution per 42 hours, and the moon's axial velocity is 1 revolution per month.
The distance from Jupiter to Io, the surface temperature and diameter of Io are the same as those of the Moon.
Geologically active are also Earth, Jupiter, Ceres, Enceladus, etc.
The geological activity of Venus and Mercury, due to the slow rotation, is extremely low. https://images.app.goo.gl/EC2iXou7XDLBWMB66
If Io gets closer to Jupiter, then the axial and orbital velocity of Io will increase, due to which the Solar Coriolis force can tear Io into numerous pieces, which will then be located along Io's orbit, forming a ring.
Perhaps the Shoemaker Comet, Levi 9, was torn apart by the Solar Coriolis effect as it approached Jupiter at perihelion.
At the time of the comet's rupture, the distance from Jupiter to the comet reached about 40,000 km, and the orbital speed was 60 km / s. https://en.m.wikipedia.org/wiki/Comet_Shoemaker%E2%80%93Levy_9
The coefficient of geological activity of planets depends on the diameter, axial and orbital speed of the planets.
The video shows how the Coriolis solar force is pulling the Earth and the Moon's orbit along the Earth's orbit. https://youtu.be/AjnA-5WFlgw?si=Ns0Opg18dlIUmRHU
Continuation: Forum of Akademgorodok Novosibirsk. The science. https://forum.academ.club/index.php?showtopic=1235578
Forum on Flagship https://vmf.net.ru/forums/viewtopic.php?t=2328
« Last Edit: February 25, 2024, 02:20:43 PM by Fermer05 »
The more complex and confusing the hypothesis, the more difficult it is to refute it.
Offline waiukuweather
Re: Earthquake hypothesis
« Reply #1 on: February 22, 2020, 03:17:39 PM »
it is true there is a slight bulge due to the moon on the earth surface (i.e a tidal bulge), as satellites have measured that
but there is no evidence that causes or triggers earthquakes
you can imagine and argue your thoughts all you like though I guess
Offline weather34
« Reply #2 on: February 22, 2020, 03:55:12 PM »
science and local myths still no closer to predicting earthquakes ..
Oarfish have been said to forecast earthquakes.
In Japan, oarfish have long figured into folklore. Smaller than the giant oarfish, the related slender oarfish (Regalecus russelii) is known there as the "Messenger from the Sea God's Palace." And according to traditional belief, if many of the fish wash up, it may signal a coming earthquake.
According to Japan Times, there could be some scientific basis to that story, even if scientists don’t currently use fish behavior to predict tremors. Kiyoshi Wadatsumi, a scientist who studies earthquakes at the nonprofit organization e-PISCO, told the paper, “Deep-sea fish living near the sea bottom are more sensitive to the movements of active faults than those near the surface of the sea.”
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
It was interesting the first few lines but too much verbal diarrhea to maintain concentration.
Condense your concepts.
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
Dark Matter
all those things are actually true
Re: The Coriolis Force on Earth and in the Universe
« Reply #6 on: June 29, 2020, 03:48:56 AM »
re 1
the moon rotates once in the 28 days it takes to orbit earth
(gravity locked)
re 2
it is visibly noticable (brighter and bigger)
Offline Garth Bock
  • Table Rock Lake Weather
Re: Stationary model of the solar system
« Reply #7 on: February 23, 2024, 09:12:56 AM »
This is garbage. The poster is spamming the forum and needs to be removed. Comets Do Not form when a planet's satellite breaks orbit during new moon phase (WTH?) and the rest of his aptly labelled "verbal diarrhea" is so twisted that it is more science fantasy delusion than fact. I recommend the poster be ignored and the Admins have a talk with them or remove them.
Offline mcrossley
    • Wilmslow Astro
« Reply #8 on: February 23, 2024, 10:15:05 AM »
He's been doing it for years, utter tripe. His signature gives a clue "The more complex and confusing the hypothesis, the more difficult it is to refute it." Spout enough words of pseudo-science and verbal diarrhea and some people somewhere will believe it.
It's a shame the forum doesn't have a "block" option.
Online chief-david
« Reply #9 on: February 23, 2024, 11:40:45 AM »
used to have a block option
« Last Edit: February 23, 2024, 11:43:54 AM by chief-david »
Offline Garth Bock
« Reply #10 on: February 25, 2024, 08:44:15 AM »
We need a block a block option or the Admins need to do something.
« Reply #11 on: February 25, 2024, 03:48:36 PM »
Yeah there used to be one. I have a couple people blocked.
Ken may have to address this one.
Offline Garth Bock
« Reply #12 on: February 26, 2024, 09:35:06 AM »
I asked for something to be done and was told that his posts now have to be approved. Looks like that is really working because his new one is more spam garbage. Anyone with basic science knowledge can see this person's post are delusional and without any scientific facts...and yet they are allowed to continue. Sad that this is allowed to go on.
« Reply #13 on: February 26, 2024, 10:20:04 AM »
The moderation setting didn’t work as expected. Removed post.
