Author Topic: Meteobridge + Ambient Weather PM 2.5 sensor = works?  (Read 1107 times)
Offline josecmorales
« on: June 20, 2019, 11:10:41 AM »
I have a Davis Vantage 2 pro with meteobridge, but i want to add Ambient Weather PM 2.5 sensor, is this sensor works with meteobridge (standalone) or i need to add another piece to make this works?
Vantage Pro2 + UV, Airlink, Purpleair, Meteobridge.
Twitter: ClimaGuayana
Blitzortung station: 2934
Weatherlink: ClimaGuayana
Offline Mandrake
Re: Meteobridge + Ambient Weather PM 2.5 sensor = works?
« Reply #1 on: July 02, 2019, 10:02:22 AM »
I believe you will also need a GW-1000 to capture the data from the PM2.5 so that the Meteobridge can get the data from the GW-1000
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
« Reply #2 on: July 02, 2019, 12:32:27 PM »
The Meteobridge can only be configured to one station hardware type at a time. If you are using it for your Davis then you can't configure it for anything else.
The Meteobridge can pick up an Ambient or Ecowitt PM2.5 but only with the Ecowitt GW1000. The Ecowitt GW1000 can pickup either brand sensors but not the other way around. Meaning an Ambient console can only pickup Ambient sensors.
I just answered this question on the Meteobridge forum:
https://forum.meteohub.de/viewtopic.php?f=56&t=14228#p29687
