Author Topic: Calculating Relative Humidity from dry and wet bulb temps and BP  (Read 2945 times)
    • Weatherelement Moline IL
For my weather station project, I've been looking for the equation for this and found several references. Here's one:
From http://maxwellsci.com/print/rjaset/v6-2984-2987.pdf
the expanded formula containing all of the intermediate equations is:
For the intermediate stuff, see the source PDF.
That will be fun to program!
Interestingly, a lot of sources use the mean barometric pressure of 1013.25024 mb instead of the current local reading. I think I'll build that equation in Excel and then see how much difference the BP makes.
Offline nincehelser
Re: Calculating Relative Humidity from dry and wet bulb temps and BP
« Reply #1 on: March 22, 2016, 02:42:25 PM »
Also, might the pressure be "absolute" rather than a sea-level pressure?
« Reply #2 on: March 22, 2016, 02:55:47 PM »
The reference cited says:
When P is the mean atmospheric pressure (assumed to be 1013.25024 mb)...
Emphasis mine... I have seen other references with the same assumption, including one, I believe, from the NWS.
Offline nincehelser
« Reply #3 on: March 22, 2016, 03:27:31 PM »
I think what they're doing there with that assumption is to reduce it down to a simpler calculation.
In physics the absolute pressure at the location would be used, but perhaps it doesn't make much difference in the meteorological world.
