Author Topic: Linksys router WRT54G as wireless repeater/extender  (Read 20808 times)
« on: November 03, 2012, 12:28:52 PM »
I have an old router.   I want to use it to extend wireless and hook it up to my DVR.
I don't think it can be done with its current firmware. I have found other firmware on the net that may work.
Has anyone done this/Can it work.
My process so far:
1. hooked it up to my current computer.
2. Can get into the setup menu/config.
Cannot get it to 'take on' my network connections/wireless.
Any help is appreciated. Time is not an issue.
Here is the info I have found
http://www.dd-wrt.com/site/support/router-database
http://www.dd-wrt.com/site/support/documentation
http://dd-wrt.com/wiki/index.php/Linksys_WRT54G_v5.0_%26_5.1_%26_6.0
http://www.dd-wrt.com/wiki/index.php/Supported_Devices#Cisco_Linksys_.28Wireless_a.2Fb.2Fg.29
Offline Lefty
Re: Linksys router WRT54G as wireless repeater/extender
« Reply #1 on: November 09, 2012, 09:26:18 AM »
It looks like you've done a bit of research on this, but you are correct that the Linksys can't be used as a repeater with the current firmware. It can, however, become ythe WAP for your network but that will require running a network cable between the routers. I don't know how your network config, but I suspect this isn't what you were looking for.
Outside buying a repeater, dd-wrt is probably your only bet on getting a repeater set up by possibly using your old router. I've never used dd-wrt and am not a unix expert so can't really help you out with configuring it. I bet the interweb has a bunch of info on how to set up dd-wrt on that router, however; those Linksys routers are everywhere !
-Steve- Peoria, AZ
Acu-rite 01515. That's it. No web page, no links, just me and my console.
« Reply #2 on: November 09, 2012, 09:29:42 PM »
Think I bricked it.  Flashing power light   will not 30/30/30
 :twisted:
yes-bricked.   Crap.   cant get an IP address from it.
« Last Edit: November 10, 2012, 06:53:45 PM by chief-david »
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« Reply #3 on: November 09, 2012, 10:10:43 PM »
Here's an example http://lifehacker.com/5563196/turn-your-old-router-into-a-range+boosting-wi+fi-repeater
What you can do with your particular linksys depends a lot on what type and version it is.
Thanks for the link, bookmarked it.
« Reply #4 on: November 11, 2012, 04:15:53 PM »
bricked
« Reply #5 on: November 11, 2012, 05:29:44 PM »
WRT54g  version 5.0
Flashing light.  unidentified network.
will not bring up an IP address like 192.168.1.1
my fault on this-no big loss but wanted to try
« Last Edit: November 11, 2012, 05:31:35 PM by chief-david »
Offline DanS
    • ThaiWx
« Reply #6 on: November 29, 2012, 07:07:03 AM »
 :twisted:
bummer! Sorry to hear that. I was just getting ready to try the same thing (while nail biting) to an old wrt-54g to get a WAP out back of the house. Reading through the requirements and procedures I found out that the version 7 model I have is not supported. So yesterday I fished 30 meters of cat 5E instead.
« Last Edit: December 08, 2012, 08:43:35 AM by DanS »
Offline Jeff
    • MansfieldWeather
« Reply #7 on: November 29, 2012, 01:09:30 PM »
I was reading on dd-wrt forum a month or so ago, there is a guy there who has figured out how to 'unbirck' that
router.  It may be worth doing some searching.
It may have been on the 'tomato' site, can't remember  :roll:
J
« Reply #8 on: November 29, 2012, 01:18:29 PM »
J
http://www.dd-wrt.com/phpBB2/viewtopic.php?t=30830
Offline Jeff
    • MansfieldWeather
« Reply #9 on: November 29, 2012, 01:35:31 PM »
Thanks Bushman, I was being lazy  .........
J
