Weather Software > Cumulus
Cumulus update and station update time off by 4 hrs
(1/3) > >>
fkapp:
I recently setup cumlus mx on a PI4.
is running great but the station update time and cumulus last update is consistently 4 hrs off. Station time is off and 4 hrs later than correct time that the cumulus last update time shows.
Pic below is screen shot.
WLL is what is used to send data to PI.
Thoughts on how to change the station time so match?
PaulMy:
Not 100% sure but think that comes from the WL.com settings - Settings (wrench icon) > Device settings > Time zone.
What is your time zone settings?
fkapp:
I checked and is set to America/ New York Time zone which is correct.
I rebooted the PI as well and no luck.
Not sure where else to check/ what else to try?
92merc:
on the PI, try running "sudo raspi-config".  Go into 4) Localisation Options.  There is the timezone setting for the PI itself.
fkapp:
Good call and thanks for help.
Did the trick. Reading the cumulusmx pi guide more closely says default time zone is UK.
Question. Is it possible to run more than cumulusmx on the pi 4?   Would like to use as plex server with USB drive but not sure if possible.  Am new to pi but learning.
Frank
[#] Next page
