Sometimes on restarting PC, Weather Display has started opening as two instances, usually one is running apparently correctly - but the other does not start downloading data. The dead instance can be closed manually.
Now this is not a big problem but today I see it started 4 instances
Any ideas what's going on?
It's an XP pro machine with 2GB of RAM, and nothing else runs on it except MSE antivrus.
It doesn't always do it, maybe 3 times out of 5.
I've installed the last 2 or 3 newest version of WD so should be a good copy but I feel a windows registry entry for it is wrong maybe?
