Author Topic: RPI Meteobridge not uploading to Weather Networks **solved**  (Read 749 times)
Offline ullises
    • Real Time weather info
« on: September 16, 2022, 10:28:53 AM »
For months i have this problem on RPI , data not being uploaded to various weather networks...
I restart RPI , data is ok for 1 minute , after that is not uploading , as seen in the atachments...
Meteobridge has latest update...
Any help would be much apreciated , thank you !
In the pictures you can see 30 minutes no upload , in the second one , 2 hours with no upload , regardless the Meteobridge says "Succes" ! [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
« Last Edit: September 22, 2022, 05:54:53 PM by docbee »
Offline Gyvate
Re: RPI Meteobridge not uploading to Weather Networks
« Reply #1 on: September 17, 2022, 03:05:19 PM »
look up the developer's replies in forum.meteohub.de where you posted the same ...  8-)
Offline ullises
« Reply #2 on: September 18, 2022, 05:43:50 AM »
Thank you , i keep in touch with the admin there , i hope he can help me ...
Offline docbee
  • Moderator
    • smartbedded
Re: RPI Meteobridge not uploading to Weather Networks **solved**
« Reply #3 on: September 22, 2022, 05:56:10 PM »
please avoid double posting in two forums. Turned out to be a user problem, solution can be found here: https://forum.meteohub.de/viewtopic.php?t=16802
