Author Topic: Sombody help please.  (Read 4209 times)
Offline cljohnso
« on: October 03, 2013, 07:21:33 PM »
VirtualVP worked fine on Windows 8.  After s system restore all I get is.......
19:16:37:643 Error        - VpConsole: Connection error: Specified comport doesn't exist
19:16:38:378 Error        - VpConsole: Connection error: Specified comport doesn't exist
19:16:39:878 Error        - VpConsole: Connection error: Specified comport doesn't exist
19:16:40:237 Error        - VpConsole: Connection error: Specified comport doesn't exist
I have searched the internet, forums, help files websites to no avail.  I have unloaded and reloaded.  Does anyone have any info on this please.
Offline cljohnso
Re: Sombody help please.
« Reply #2 on: October 04, 2013, 10:44:28 AM »
That is the same message no matter which COM port I try.  I've been from 2 through 30 thus far.
Offline Beaudog
« Reply #3 on: October 04, 2013, 10:55:10 AM »
If you load weather link and then tell it to auto detect  com port under setup what does it tell you?
Offline cljohnso
« Reply #4 on: October 04, 2013, 11:26:42 AM »
It goes to COM 11
Offline cljohnso
« Reply #5 on: October 04, 2013, 11:37:24 AM »
OK all set.  I did not think VVL and WL could share the same port.  I thought everybody had to be on their own port.
Thank you very much for taking the time to reply to what seems now like a dumb question.
Offline Beaudog
« Reply #6 on: October 04, 2013, 12:34:09 PM »
They can not share the same com port if you try and use them at the same time.   If only one is running at a time you can use the same com port.
Although you have me confused now.  The whole purpose of VVP is so that you can run multiple programs at one time.  VVP should be on com 11 and WL should be on some other and any other program running at the same time should be on a different com port.  Like this>
Offline cljohnso
« Reply #7 on: October 04, 2013, 01:52:17 PM »
I don't understand this com port stuff at all.  My mistake.  When all is said and done VVP is on 11.  WL is on 7 VWS is on 8.  I can not get VPLive to work at all.  I'd like to tackle TCP/IP but for me that is a lost cause.
Offline Beaudog
« Reply #8 on: October 04, 2013, 02:09:23 PM »
What are you using for a serial com port redirector?    Com O com  Lantronix?    The com ports you are using look funny. Normally the com port redirector would be setup for odd and even pairs
5=6
7=8
9=10
Thus in your case   wl 6,  vws 8, vplive 10
Offline cljohnso
« Reply #9 on: October 04, 2013, 02:14:41 PM »
I am using Virtual Serial Port Emulator.  The way they explained to do it was
7=17
8=18
9=19
10=20
In your example I would enter the higher number as opposed to how I have it now entering the lower number?
Offline Beaudog
« Reply #10 on: October 04, 2013, 02:19:31 PM »
That is correct in most cases you use the higher number   should be   Wl 17, vws 18, vpl 19
Offline cljohnso
« Reply #11 on: October 04, 2013, 02:27:41 PM »
Can not find com o com through google Are either one of those easier to use?
Offline Beaudog
« Reply #12 on: October 04, 2013, 02:30:33 PM »
Don't know they are all kinda hard to setup.     My VVP looks like this   The com ports are for the netbook that actually runs the uploads.    The TCPip ones are for a separate computer on my network.
Offline cljohnso
« Reply #13 on: October 04, 2013, 02:38:34 PM »
The com settings look very similar to mine.  I think I'll leave well enough alone.  Everything seems to be OK now except VPLive which I can play around with.
Offline Beaudog
« Reply #14 on: October 04, 2013, 02:45:28 PM »
Look at the bottom of the setup page for VVP.
And if you look at mine I have VVP  set to 16, 17, 18.
WUHU is then set to 6, WL to 7 and VPLIVE to 8
This is backward from what I told you earlier which was wrong.
Offline Beaudog
« Reply #15 on: October 04, 2013, 02:52:18 PM »
Try this set the vvp and vplive like this and see if vplive does not work
Offline cljohnso
« Reply #16 on: October 04, 2013, 02:59:30 PM »
Connection refused using TCPIP....  Also at bottom is what I get with Com port
5:59:138 Warning      - Failed to open archive file (C:\WeatherLink\CJ\2013-10.wlk)
14:56:00:153 Error        - Console: Failed to connect to TCP/IP port 127.0.0.1:5511 (Connection refused)
14:56:00:153 Warning      - Connection interrupted, will try to reconnect in 15 seconds
14:56:05:247 Warning      - Failed to open archive file (C:\WeatherLink\CJ\2013-10.wlk)
14:56:06:279 Error        - Console: Failed to connect to TCP/IP port 127.0.0.1:5511 (Connection refused)
14:56:06:279 Warning      - Connection interrupted, will try to reconnect in 30 seconds
14:56:15:154 Warning      - Failed to open archive file (C:\WeatherLink\CJ\2013-10.wlk)
14:56:16:186 Error        - Console: Failed to connect to TCP/IP port 127.0.0.1:5511 (Connection refused)
14:56:16:186 Warning      - Connection interrupted, will try to reconnect in 45 seconds
14:56:36:280 Warning      - Failed to open archive file (C:\WeatherLink\CJ\2013-10.wlk)
14:56:37:312 Error        - Console: Failed to connect to TCP/IP port 127.0.0.1:5511 (Connection refused)
14:56:37:312 Warning      - Connection interrupted, will try to reconnect in 1 minutes
14:57:01:188 Warning      - Failed to open archive file (C:\WeatherLink\CJ\2013-10.wlk)
14:57:02:204 Error        - Console: Failed to connect to TCP/IP port 127.0.0.1:5511 (Connection refused)
14:57:02:204 Warning      - Connection interrupted, will try to reconnect in 2 minutes
14:57:16:939 Warning      - Failed to open archive file (C:\WeatherLink\CJ\2013-10.wlk)
14:57:18:627 Warning      - Unable to send Wake Up Console (Timed out)
14:57:20:314 Warning      - Unable to send Wake Up Console (Timed out)
14:57:22:002 Warning      - Unable to send Wake Up Console (Timed out)
14:57:23:689 Warning      - Unable to send Wake Up Console (Timed out)
14:57:23:689 Error        - Console: Several consecutive failures of console to respond. Will try to reconnect.
14:57:25:377 Warning      - Unable to send Wake Up Console (Timed out)
14:57:27:065 Warning      - Unable to send Wake Up Console (Timed out)
Offline cljohnso
« Reply #17 on: October 04, 2013, 03:04:10 PM »
My com port in VPLive is set to 9.  When I open VPTools.ini it says 6 and does not change.
