Author Topic: VirtualVP Temporarily Unable to be Doenloaded  (Read 12936 times)
Offline Weather Display
Re: VirtualVP Temporarily Unable to be Doenloaded
« Reply #25 on: September 03, 2013, 12:55:31 PM »
I will add ability to set the address/port
(e.g to 192.168.1.5 or something)
Brian
info@weather-display.com
Offline Joel
    • PWS Lobbes
« Reply #26 on: September 03, 2013, 02:24:49 PM »
I installed the latest version of WD found in ZIP and checked the "Data share TCP/IP to 127.0.0.1 port 5511" box in the configuration screen.
In Weatherlink (5.9.3 or 6.0.3) on the same PC I configured the Communication Port as
Communication : TCP/IP
TCP Port : 5511
Remote IP address : 127.0.0.1
When pushing the Test button, I get the error message "TCP/IP : Communication error found.  Check settings and try again"
I made a quick & dirty test with PuTTY connecting 127.0.0.1:5511.  When the "data share ..." is disabled in WD, I get an error.  Then the option is enabled, no error message anymore in PuTTY but an empty screen.
FYI, during the installation of Weatherlink I get a warning about a "newer driver 6.4 already installed".   I guess it is related to Silicon Labs CP210x USB to UART Bridge which is 6.4.0.0.
The same configuration ran with VVP but communication crashed after a few hours.
« Reply #27 on: September 04, 2013, 11:25:20 PM »
this feature in WD will send out the Davis LOOP data every time WD gets live data from the station
once a connection has been made to the 127.0.0.1, port 5511 TCP/IP
(i.e you need to have WD getting live data from the station)
did you try setting weather link up to get real time LOOP data?
(i.e broadcast screen open)
Brian
Offline Andy Thompson
  • Southern Minnesota Live Weather
  • Madelia and Thompson Farms
« Reply #28 on: September 05, 2013, 07:21:13 AM »
Things must be going south quick because a few months when I asked to find my original registration key, he gave me the default one for free. Poor Steve  :-(
Regards,
Andy Thompson
www.somnwx.com
Offline Joel
    • PWS Lobbes
« Reply #29 on: September 05, 2013, 09:45:54 AM »
Not sure to understand what you mean
Please see WD config in capture1.png screenshot
WD is running and receiving data.
In capture2.png you can see WL configuration and error message when I press the TEST button
It is the same WL configuration I used sucessfuly with VVP.   The problems with VVP were connection problems after a few hours.
Thanks for your help
Joel.
Offline Joel
    • PWS Lobbes
« Reply #31 on: September 05, 2013, 11:15:13 AM »
I made a new test with Putty open to 127.0.0.1 : 5511  as raw connection (instead of ssh as in my first test)
I receive a line of data more or less every second :
Welcome to OverByte ICS TcpSrv
O     tQ4{(2
LO  tQ4{(2
LO  tQ4{(2
LO  tQ4{'2
LO    tQ4{'2
8LO  tQ4{'2
8LPuTTYPuTTYO        tQ4{'2
LO    tQ4{'2
L
The connection is broken as soon as I close WD, so we can suppose these data come from WD.
« Reply #32 on: September 05, 2013, 02:41:09 PM »
Hi
yes, that test shows its working, thats the LOOP data
WD is not setup to resond to a test send (or any other data sends) from WL (Or any other software)
at this stage
if the software can be set to just start accepting live LOOP data, then it should work
(see my post above about setting WL to bulletin mode?)
Brian
Offline Joel
    • PWS Lobbes
« Reply #33 on: September 05, 2013, 03:56:59 PM »
I'm not able to open bulletin.
See error message attached
« Reply #34 on: September 05, 2013, 04:00:09 PM »
I dont have WL here...I guess I better install it...(is there a URL to do that?)
also there is a bit of debug info about this in WD under view, WS2010/WS2500 setup
anything show up there?
(or under view, program event log)
Brian
Offline Joel
    • PWS Lobbes
« Reply #35 on: September 05, 2013, 04:45:43 PM »
Hi, this is the full content of this debug screen :
Loaded all time records
loading the data file month92013.inf
Connecting com port 3
Com port connected OK -> 3
Time period too short
All data downloaded or did not sync correct!
Formating downloaded data now into actual data
Weather station type number 31
starting get data timer now
client connected
Doing checking of time zone calculation
Daylight saving in use
resetting the com port
Resetting coldest night values 18:00 05/09/13
Current warmest day value (oC) 25.4 18:01 05/09/13
Resetting coldest night values 18:01 05/09/13
Resetting coldest night values 18:03 05/09/13
Reset overnight minimum temp 21:00 05/09/13
Reset overnight minimum temp 21:01 05/09/13
client connected
client connected
client connected
(for your info, local time is now 22:45)
There is no link to install WL because the installation CD comes with the datalogger.
There is indeed a link on Davis website, for upgrade only : http://www.davisnet.com/support/weather/downloads/software_sftwr.asp
I will sent you in a few minutes an e-mail on the address stated on your contact webpage.
