Author Topic: WD eval ver  (Read 7294 times)
Offline Anthony
    • Anthony's Weather
WD eval ver
« on: October 23, 2007, 01:15:58 PM »
Just downloaded the most recent version of WD. It tells me when I run it that my trial has expired???? Any idea(s) what might be happening. I'm considering running WD along with VWS. I like some of the reports that are created by WD the VWS doesn't do. I was planning on running WD in stationless mode. What csv file(s) need to be imported? Or would it be better to run WD along with VWS on the same computer? I realize this would require a comport sharing program. I have a OS WMR-968 station. Any help would be appreciated.
Anthony
WB8YUE
Offline racenet
    • NH Weather Data
Re: WD eval ver
« Reply #1 on: October 23, 2007, 02:00:54 PM »
If you have had it installed on your computer before, yeah, it will show as expired now.
It's only a one time deal.  ;)
Bob
Offline Anthony
    • Anthony's Weather
Re: WD eval ver
« Reply #2 on: October 24, 2007, 08:22:17 AM »
Got the first problem taken care of. Now on to my other questions. What file or files (csv) do I need to inport into WD. Right now I have it reading a VWS data csv file. Can you import any or all of the database files from VWS?
Anthony
WB8YUE
Offline Anthony
    • Anthony's Weather
Re: WD eval ver
« Reply #3 on: October 24, 2007, 03:04:12 PM »
As I said. I have WD pointing to the csv file(s) created by VWS. Note, WD is not on the same computer is VWS. I have WD reading the data.csv file that is in the vws\data dir. It's displaying the temp & dumidity correctly. Baro with in .01 rain is not being shown at all. I have tried the data 2 & dbase with the same results. Have even tried the daily file in vws\data\csv with the same results. Is there a port sharing program that will work across a network or does VWS and WD need to be on the same computer with a port sharing program?
Anthony
WB8YUE
Offline Curly
    • Michiana Weather
Re: WD eval ver
« Reply #4 on: October 24, 2007, 05:26:18 PM »
Just curious, why import data from one program to another.
Does VWS produce something that WD can't?
Offline Anthony
    • Anthony's Weather
Re: WD eval ver
« Reply #5 on: October 25, 2007, 08:52:28 AM »
WD is cabaple of producing reports that VWS can not. Or so I've heard.
Anthony
WB8YUE
Offline Curly
    • Michiana Weather
Re: WD eval ver
« Reply #6 on: October 25, 2007, 05:11:13 PM »
WD does have a wider variety of tags than VWS.
This is the part that I'm not fully understanding.
Is there an advantage to why WD is pointing at the VWS csv's?
Offline carseman
  • WH 1081 Weather Display Win XP
    • CarseWeather
Re: WD eval ver
« Reply #7 on: October 25, 2007, 05:23:00 PM »
Anthony,
I would recommend using a virtual comport program rather than the CSV method.  I use GPSGate from www.franson.com to link WD and VWS to my WM918 and have done so for almost a couple of years without problems.  It sells itself as a GPS sharing program, but is great at sharing com ports. You can even use it to share com ports to a local machine and export a virtual com port via TCP/IP. (You could install a 14 day trial version on both your current machines).
Before using a virtual com port program, I was finding the odd data quirk being exported from VWS to WD - now both programs read the WM918 independently.
Chris
« Last Edit: October 25, 2007, 05:25:26 PM by carseman »
Offline Anthony
    • Anthony's Weather
Re: WD eval ver
« Reply #8 on: October 26, 2007, 08:21:38 AM »
Curly,
WD can be run in 3 differend modes:
1 Weather station conected to computer running WD
2. CSV mode. WD pulls it's data from a CSV file created by another weather station program (VWS)
3. Stationless mode. Data is manually entered. (I assume)
Caresman, thanks for the info. Will check it out.
Anthony
WB8YUE
Offline jmcmurry
  • Jim McMurry
    • Juneau County Weather
Re: WD eval ver
« Reply #9 on: October 26, 2007, 09:14:51 AM »
Normally folks will use local METAR data in this mode.
- Jim
Offline Curly
    • Michiana Weather
Re: WD eval ver
« Reply #10 on: October 26, 2007, 06:08:38 PM »
I just couldn't see what advantage VWS has over WD.
Why not have the console connect with WD and let it do all its weather station stuff and let VWS handle the metars, mesonets and other data? There would be no comm port program needed, your station data will be about 6 seconds newer, and neither program will be dependant on the other.
Offline Anthony
    • Anthony's Weather
Re: WD eval ver
« Reply #11 on: October 27, 2007, 08:52:37 AM »
Two programs can not use the same port on the same computer. You need to have some sort of port sharing program installed. And the more I mess with WD. I believe I'll just stick with VWS for now.
Anthony
WB8YUE
Offline windy
    • Grahams Beach Weather
Re: WD eval ver
« Reply #12 on: October 29, 2007, 01:56:24 AM »
what weather station type do you have Anthony (maybe you could update your profile?)
if a wmr968 , then you can use a Y splitter
also:
what is this , or so I've heard, bit all about that you keep on repeating?
can you give more information on your whole motives on this venture Anthony?
(I am curious)
also, what are your PC specs (maybe add those to your profile as well) (because in an email you sent me, it does not look like your pc would be capable of running both the programs at the same time on the same pc, yes no?)
Offline Anthony
    • Anthony's Weather
Re: WD eval ver
« Reply #13 on: October 29, 2007, 08:17:24 AM »
As for the station. It's a WMR-968. The weather computer is a Gateway with a 433 MHz processor and 128 meg of memory. So your right. It would not be capable of running both programs. I am aware of the "Y" splitter. As for the reports. This is what I gathering just from what little bit I've read. The program does infact have many tags that VWS does not (to many to list). It does fire weather. Whic I think is cool. Would be a great addition to VWS. I am only running and trial right now and will probably not purchase the program. I'm concentrating more now on saving $$$ for a new Davis next spring.
As for the profile. I will get it updated. Thats one of the biggest gripes on the other forum I belong to and am a Global Moderator.
Anthony
WB8YUE
Offline racenet
    • NH Weather Data
Re: WD eval ver
« Reply #14 on: October 29, 2007, 10:44:33 AM »
Get'er done!  \:D/
