Weather Station Hardware => What Weather Station Should I Buy? => Topic started by: Hulakai on January 29, 2023, 06:41:21 PM
I'm new here and buying my first pws. I'm trying to decide between the GW2001 and Tempest. I like the simple design and lack of moving parts in both. The difference in cost between the two is about $150 for me (Canada) but that isn't necessarily the deciding factor. If they're more or less equal in performance then yes I like the price of the GW2001 and the fact that I can add more sensors...but if the Tempest performs much better and the Alexa integration is useful then I'd spring for the Tempest.
Thoughts ?
Kevin
Overall, the plus side of Ecowitt is that you can separate the sensors. The Ecowitt WS90 Wittboy is heated, while the Tempest is not. If you live in a cold climate, you may need heating to keep your anemometer running smoothly during cold and snowy weather. Both the Tempest and also the Ecowitt have average tactile rain gauges. Ecowitt, on the other hand, has a good WH40 trough rain gauge that can be purchased with a longer funnel. In rainy and snowy weather the sonic ws90 measures the wind accurately, the sonic wind gauges LCJ, Davis have problems with this and give erroneous values.
You also need to remember that using a heater in the WS90 causes temperature drifts, so you should equip yourself with a separate sensor, such as WH32EP, and place it in a good radiation shield, such as at the recommended measuring height of 2 meters above ground level.
If you want reliable temperature readings, you need to buy a good radiation shield for the WH32EP sensor, such as: Metspec, Barani Meteoshield Pro, A-Ster. Ecowitt does not have a good radiation shield in its product range that protects properly from solar radiation. Their $20 shield overstates the temperature by up to 4-6 degrees on solar days, so you have to buy it separately.
Take a peek at this kit he recommends for you:
https://shop.ecowitt.com/products/wittboy
https://shop.ecowitt.com/products/wh32_ep
https://shop.ecowitt.com/products/extension-cord
https://shop.ecowitt.com/products/wh40
https://shop.ecowitt.com/products/wh40-heightening-block
https://shop.ecowitt.com/products/bird-spikes
https://shop.ecowitt.com/products/wh57
Optionally, you can opt for a Wittboy with a console and connect the rest of the sensors to it
https://shop.ecowitt.com/products/wittboy-pro
You can purchase proven radiation shields from the following sites
https://www.baranidesign.com/radiation-shields
https://metspec.net/radiation-shields/
(recovered WF user and field tester here) - I could never recommend the Tempest at this point. The rain is horribly inaccurate for most people, the lightning is basically totally made up, even temperature is questionable in summer sun, and they still seem to have obvious quality control issues with lots of failed/returned hardware.
They're very nice people and have a very good set of APIs and support forums, but to me I would definitely shop elsewhere regardless of price....but I'm kinda an old-school 'stuff should just work right out of the box' engineer type.
Your choice likely comes down to your budget and what's most important to you.
My ecowitt stuff is basically for play and to get a bunch of $12 room t+h sensors working, but the T+H sensors seem accurate to me. The 'ol VP2 is the primary gear here. If it ever died I'd just buy another Davis.
Excellent feedback, thank you very much
K
