Weather Software => Weather Display => Topic started by: Jumpin Joe on October 23, 2021, 01:36:09 PM
WD is not showing the information for Solar and UV on my site. I have a Davis 6163 wireless with Solar & UV. I have UV and Solar checked in WD.
Can anyone tell me what be causing this?
Joe
as in this site?
https://joesweather.info/
I would think you would need to enable that in the web page setup/script settings?
as in this site?
Yes.
I have enabled them.
maybe try contacting the author of the script maybe
but also make sure the switch is in WD under control panel, solar setup
Thanks…. It is on.
I’m hoping Ken True or Brian from WD will see this post and reply with their thoughts.
In your Settings-weather.php, you have
$SITE['UV'] = false; // set to false if no UV sensor
$SITE['SOLAR'] = false; // set to false if no Solar sensor
That should be $SITE['UV'] = true; // set to false if no UV sensor
$SITE['SOLAR'] = true; // set to false if no Solar sensor
to enable the display of the station's UV and Solar sensor data.
In your Settings-weather.php, you have $SITE['UV'] = false; // set to false if no UV sensor
Never thought of checking that script.
Thanks, Ken!
