I've picked up a working Texas Weather Instruments WLS-8000 unit, minus sensors and power supply/wall wart.
I've got stuff to make most of the sensors work, and have a PS from another type of TWI station that power the unit just fine.
However, there is a 12 v gelcel onboard that apparently powers this unit during loss of wall power, and I'm not sure what the power supply looks like.
There is a red and black wire that goes to the boards pretty straight forward. There is a common ground with the battery on board, and a three wire attachment through a Molex, red/green/black that goes to the wall wart.
I'm sure that the supply just furnishes power to the station over red and black, and the green (which goes to the + side of the battery) is fed with a charging/trickle current when local power is present.
I'm not sure how the wall wart flips to a power-out mode. Is there a steering diode that is biased during normal power that now feeds from the green wire over to the red when local power outage occurs?
I'm hoping someone here has one of these and can tell me what the layout is so I can make use of the backup power if local ever goes out. Doesn't happen often but would be nice to use all the functions of the station.
I checked with TWI a few months ago when I got this and they wanted $80 plus shipping for the wall wart. I should be able to wire it up myself for considerably less if I knew the layout, since my wife isn't so sure that $80 plus shipping is vital for the few times the power fails. You know how that goes.
Any thoughts? Anyone have one of these and can take a look at what is on the power supply end?
Dale
