Author Topic: Spring/Summer '20  (Read 19614 times)
Re: Spring/Summer '20
« Reply #175 on: June 09, 2020, 10:24:44 AM »
At least you will get some rain. Could do without those wind gusts though.
Offline DRoberts
« Reply #176 on: June 09, 2020, 09:17:44 PM »
Lowest barometer pressure 29.34 this morning. For a June low pressure, that has got to be very unusual for the Plains. More like a January event.
    • Watts Bar Weather
« Reply #177 on: June 12, 2020, 08:23:35 PM »
June 6th tornado goes through Orlando, FL
https://www.youtube.com/watch?v=9v26hDHr3UY
Offline Notsorusty
« Reply #178 on: June 13, 2020, 11:19:29 AM »
This season's whiplash continues. We were at 90.1 earlier this week (95.2 earlier this month) and woke up to 51.6 this morning.
Station Name: Silver Creek II
Latitude / Longitude: 41.925° N, -87.872° W
Elevation: 633
City: Franklin Park
State: IL
Hardware: Ambient Weather WS-2902D
« Reply #179 on: June 15, 2020, 10:14:28 PM »
93 tomorrow with south winds up to 30 mph
It has been a crazy few weeks. and windy.
« Reply #180 on: June 16, 2020, 07:49:38 AM »
Beautiful day yesterday in central Florida. Temp was 89 but DP's in the mid 60's and a nice north wind made it great. Unloaded 3 pick up loads of dirt and 2 pallets of sod and barley broke a sweat.
Offline DRoberts
« Reply #181 on: June 16, 2020, 12:16:50 PM »
Ditto here. Hot, above normal by 10 or more degrees every day and winds gusting 35-40.
Offline jas340
    • Lone Pine Ranch  Horseshoe Bend, Idaho  USA
« Reply #182 on: June 17, 2020, 08:25:11 AM »
It's been a very cold and rainy June so far at my location. I've been running my pellet stove in the morning for the last 5 days. We had wet snow on the 7th. Yesterdays high was 52 while the high last December 22nd was 58. Winter storm warning above 5500 feet 100 miles NE of here. The heat turns on here like a light switch once the high sets up over the 4 corners region bringing the monsoon season to Arizona while cutting off the cold rain storms from the Pacific.
http://horseshoebendidahoweather.com/template/indexDesktop.php
« Reply #183 on: June 17, 2020, 09:12:53 AM »
If you do Twitter, the MPLS NWS is reliving the 2010 storm. 600,000 without power state wide.
I did not have power for three days. Hijacked a generator from Home Depot.
Spent 8 hours bailing out my sump basket because my battery backup died. We still have the mixing bowl-We call it old faithful.
89 mph wind and 4 inches of rain.
Offline alanb
« Reply #184 on: June 17, 2020, 12:48:50 PM »
I am curious about your battery sump pump backup. How long did it run before the battery died? I have a Wayne backup pump that has a 4 year old battery. I tested it last week after a rain and let it run for 8 hours. It was cycling approximately every 1.5 minutes and runs for about 20 seconds each cycle. My battery still showed 80% after 8 hours, but I wonder how quickly it would drop if I had left it running. It was bed time and I didn't want to chance it, so I plugged my primary pump back in.
« Last Edit: June 17, 2020, 12:50:28 PM by alanb »
Alan - Ambient WS-2000, WH31E x5, WH31L, Ecowitt WN32(WH32E)
          Airthings Corentium Home Radon Detector 223
« Reply #185 on: June 17, 2020, 01:51:42 PM »
In that house I had a this
The dumb thing I didn't do is to replace the battery after 5 years. So when that storm hit-it was 7-8 years old and only worked for a short time.  I then borrowed a small generator from the neighbor and it worked for a while. It quit and the wife and I bailed out the basket until my FIL showed up with a generator.
Most batteries will run 8 hours continuous and 3 days when cycled off and on.  That one ran for 3 days sporadically in 2005 or so.
When I was cleaning today-I found the bowl. It just does not feel right throwing it out after it saved us 1000's of dollars.
Offline Notsorusty
« Reply #186 on: June 17, 2020, 03:56:33 PM »
That's the backup to the backup! I hope you didn't have to throw the water too far, 2 qts at a time.
Elevation: 633
City: Franklin Park
State: IL
« Reply #187 on: June 17, 2020, 04:59:01 PM »
Wife dumped it into a 5 gallon bucket. I gingerly walked 10 feet to the laundry sink.
« Reply #188 on: June 18, 2020, 07:20:48 PM »
getting heavy rain and wind now. Much needed. More at home than at school.  A three mile difference.
0.12 school
0.83 home
Offline alanb
« Reply #189 on: June 18, 2020, 09:07:05 PM »
0.12 school
0.83 home
Send some down our way Chief... grass is turning brown. :-)
Offline Notsorusty
« Reply #190 on: June 19, 2020, 10:43:26 AM »
We haven't seen any rain here in Chicago for eight days. Stuck between two stationery weather systems. NWS Chicago has some encouraging words for us today:
"I suppose if a bird were to flap its wings hard enough, a stray shower or two may pop up across the area but by and large dry conditions are expected today."
Borchardt
Elevation: 633
City: Franklin Park
State: IL
Online Bunty
« Reply #191 on: June 19, 2020, 03:47:45 PM »
Finally June gets some much needed rain.  Over 2" here, so far.
Offline DRoberts
« Reply #192 on: June 23, 2020, 08:34:25 AM »
2012 Archive
May be the wrong place for this.
In 2012, 23-27 June, we had a 5 day period of temperatures I won't easily forget here in NW KS. Culminated on 27 June with a national high temperature of 115. Don't want to repeat this again.  [ You are not allowed to view attachments ]
« Reply #193 on: June 25, 2020, 07:15:19 PM »
Time for the monsoon, 111F yesterday, 112F today. Not only, the wildfire just north of town in the Catalina's is approaching 100,000 acres with little containment and about 1000 folks involved fighting it. =D>  The only thing that will stop it is rain or lack of fuel. The former would be preferable.
« Reply #194 on: June 25, 2020, 10:13:48 PM »
Good luck out there dude.
« Reply #195 on: June 29, 2020, 10:13:35 AM »
A few areas in western Wisconsin had 8 inches of rain. Floods, washed out roads.
We have a heat advisory for hot and humid conditions.
I find it funny that Minn gets heat advisory for 90F with humidity and Florida gets warnings for 50. Both telling people to stay inside.
« Reply #196 on: June 29, 2020, 11:14:06 AM »
Warnings for 50?
« Reply #197 on: June 29, 2020, 11:19:39 AM »
Warnings for 50?
60?
« Last Edit: June 29, 2020, 11:34:26 AM by chief-david »
Offline yotaman
« Reply #198 on: July 03, 2020, 05:31:06 PM »
Hit 96 today. Hottest of the year so far and tomorrow is supposed to be the same. Dew point has been sitting at 70 so it hasn't been as bad as it could be.
Offline alanb
« Reply #199 on: July 03, 2020, 06:47:17 PM »
It's about time for the Japanese beetles to show up and strip my birch, linden, crab and other tree and shrub varieties which are looking great right now. I hate those damned beetles.
