Author Topic: wxStory 3.0  (Read 8867 times)
Offline drrehak
Re: wxStory 3.0
« Reply #25 on: April 13, 2022, 07:47:47 AM »
Thanks Jim.  Glad to help.
Dan Rehak | Pittsburgh PA
Davis Vantage Pro 2 Plus | Meteobridge Pro
Local Site | Raspberry Pi 4B
Offline Jumpin Joe
    • Joe’s Weather
Re: wxStory 3.0
« Reply #26 on: April 13, 2022, 10:00:12 AM »
Just installed this and I am getting a bunch of errors. Can you tell me what I have done wrong?
Warning: fopen(./wscache/wsimg_iln_weatherstory.png): failed to open stream: No such file or directory in /home/joes/www/www/wxStory_inc.php on line 256
Warning: fwrite() expects parameter 1 to be resource, bool given in /home/joes/www/www/wxStory_inc.php on line 257
Warning: fclose() expects parameter 1 to be resource, bool given in /home/joes/www/www/wxStory_inc.php on line 258
Warning: Division by zero in /home/joes/www/www/wxStory_inc.php on line 680
Warning: imagecreatetruecolor() expects parameter 2 to be int, float given in /home/joes/www/www/wxStory_inc.php on line 681
Warning: imagecopyresampled() expects parameter 1 to be resource, null given in /home/joes/www/www/wxStory_inc.php on line 682
Warning: imagedestroy() expects parameter 1 to be resource, null given in /home/joes/www/www/wxStory_inc.php on line 694
Warning: fopen(./wscache/wsdata_iln.php): failed to open stream: No such file or directory in /home/joes/www/www/wxStory_inc.php on line 479
WEATHER STORY
Wilmington
Weather Forecast Office
Warning: include(wxStory_drop_inc.php): failed to open stream: No such file or directory in /home/joes/www/www/wxStory_inc.php on line 718
Warning: include(): Failed opening 'wxStory_drop_inc.php' for inclusion (include_path='.:/usr/local/php73/lib/php') in /home/joes/www/www/wxStory_inc.php on line 718
Weather Story
Data Courtesy of Wilmington Weather Forecast Office[/color]
Joe
www.joesweather.info
https://joesweather.info
WeatherLink Live
Offline drrehak
Re: wxStory 3.0
« Reply #27 on: April 13, 2022, 10:32:43 AM »
First thing to check is that you created the wscache directory and the path matches that in the script.  From your output it looks like it should be
/home/joes/www/www/wscache
Second, make sure there is write permission to that directory so the script can create the files.
Offline drrehak
Re: wxStory 3.0
« Reply #28 on: April 13, 2022, 10:39:02 AM »
Also, looks like you didn't install wxStory_drop_inc.php
You need to get the entire zip file from earlier in the thread, not just the latest .txt file.  There are more instructions in the .zip
Offline Jumpin Joe
    • Joe’s Weather
Re: wxStory 3.0
« Reply #29 on: April 13, 2022, 11:22:01 AM »
Thank you, Dan.
You are correct, the only script I downloaded and installed is wxStory.php
I’ll complete the installation a little later on today.
Joe
WeatherLink Live
Offline Jumpin Joe
    • Joe’s Weather
Re: wxStory 3.0
« Reply #30 on: April 13, 2022, 01:12:00 PM »
Completed the installation of ALL the folders and files.
Life is good.
Thanks again, Jim and Dan!
Joe
WeatherLink Live
Offline jmcmurry
  • Jim McMurry
  • Davis Vantage Pro 2 Plus Wireless.
    • Juneau County Weather
Re: wxStory 3.0
« Reply #31 on: April 15, 2022, 02:40:50 PM »
Attached is version 3.05 which adds a configuration item for validation.  <script type="text/javascript"> is not allowed in HTML5.
It also cleans  up the WFO array which was missing some spaces in the WFO names.
- Jim.
Forum Search and Google Can be Your Best Friends
Offline drrehak
Re: wxStory 3.0
« Reply #32 on: April 18, 2022, 12:45:02 PM »
Hi Jim
Been playing with the script some more.  I noticed a couple times that I would get
the show/hide caption button, but no text.
Today Caribou Maine is showing a story image and caption on there site, but $wsdata ends up as a zero length string in the script.  Not been able to figure out when the script isn't able to find the caption (finding the cases when it doesn't work has been trial and error).  Haven't tried to dig into all the page parsing code.
    - Dan
Offline jmcmurry
  • Jim McMurry
Re: wxStory 3.0
« Reply #33 on: April 19, 2022, 04:46:35 AM »
Dan,
There are some of the eastern sites that never have any notes.  Then there apparently are some that are sporadic.  I should be able to insert a "not available" note when they don't have one.  Busy today but should be able to work on it tomorrow.  Thanks for finding these things.
- Jim
Offline drrehak
Re: wxStory 3.0
« Reply #34 on: April 19, 2022, 09:27:49 AM »
Hi Jim,
Thanks.  No rush at at -- whenever you get to it.
In this case, the problem isn't their site, its the script.
Here a screen grab of what Caribou is showing today -- includes the note.
And here's their HTML:
<body><pre style="word-wrap: break-word; white-space: pre-wrap;">Gusts to 65 mph from east/southeast near the coast today. Heavy rain Downeast from ~7am-2pm. Locally 3ā€¯ rain could fall in just a few hours. Minor coastal flooding around the early afternoon high tide.
Northern Maine, snow and sleet totals generally &lt;1ā€¯, except higher amounts over higher elevations. Changing to rain by early afternoon.
</pre></body>
And here's what the script generates:
<?php
$mainStory
= array (
#39;WeatherStory&#39; =>
array (
=> &#39;&#39;,
=> &#39;&#39;,
=> &#39;https://www.weather.gov/images/car/WeatherStory.gif&#39;,
=> &#39;https://www.weather.gov/car/&#39;,
=> &#39;./wscache/wsimg_car_WeatherStory.gif&#39;,
=> &#39;gif&#39;,
=> &#39;WeatherStory&#39;,
=> &#39;car&#39;,
=> &#39;Caribou&#39;,
$altStory = array (
$nfo = &#39;Caribou&#39;;
$hdlnr = array (
=> &#39;     <td style="text-align: center; background-color:#F0F7FF; padding: 6px 0px 6px;"><a href="/weather/st/wxstory.php?i=car&amp;ifn=WeatherStory" title="" style="text-decoration: none; color: #0071BC; font-size: 1.3em;">Weather Story</a></td>&#39;,
From what I can tell, array[1] shouldn't be empty.  Something wrong it parsing.
I do see that this site is wrapping the caption in a <pre> unlike other sites.
And they have the "ā€" in the output.  I've not be able to figure out all the
script code to tell if this is the problem.
If $wsdata is legitimately empty, adding a strlen around the row will turn it and the button off, but that's not what should happen here.
<?php if(strlen($wsdata)>0){ ?>
 <tr>
<?php if ($UseShowHide) { ?>
 <td> <!-- align was center -->
 <div id="myDIV" style = "width: <?php echo $tablewdth?>px;text-align: left;background-color: white;margin-top: 5px; display: <?php echo $CDisplay?>;">
<?php echo $wsdata?>
</div>
 <button id="myButton" style="float: left;background-color: #0071BC; margin-top: 5px; padding: .3em; -moz-border-radius: 5px;-webkit-border-radius: 5px;border-radius: 6px;color: white;font-size: 12px; font-weight:600; text-decoration: none; border: none; " onclick="myFunction()"> <?php echo $CCaption;?>  </button>
 </td>
<?php } else { ?>
  <td style="text-align:justify; line-height: 160%;"><?php echo $wsdata?></td>
<?php ?>
 </tr>
<?php ?>
    - Dan
Offline zeppline
    • Las Vegas Weather Guy
Re: wxStory 3.0
« Reply #35 on: April 19, 2022, 08:40:21 PM »
I downloaded wxstory and it working except I can not get the map to load. it is in images/WS_map but the program can't find it. If I use the web "lasvegaswx.com/images/WS_map" it is there? What am I missing.  Thanks Joe
Offline jmcmurry
  • Jim McMurry
Re: wxStory 3.0
« Reply #36 on: April 19, 2022, 09:29:06 PM »
Joe, the map file must be named WS_map.png.  Give that a try.  - Jim
Offline zeppline
Re: wxStory 3.0
« Reply #37 on: April 19, 2022, 10:02:40 PM »
Thanks Jim after 3 days I new it was something small. I thought the program added the png. I know enough to get in trouble. Thanks again Joe
Offline jmcmurry
  • Jim McMurry
Re: wxStory 3.0
« Reply #38 on: April 20, 2022, 07:34:06 AM »
I'm glad you got it working Joe.
Attached is Ver 3.06 that takes care of the eastern stations that had no captions/notes.    Thanks for catching this too Dan.
Offline Silversword
  • --Stan Y.
    • Up Country Maui Weather
Re: wxStory 3.0
« Reply #39 on: April 21, 2022, 02:30:17 PM »
Hi All,
Thanks Jim for updates.  It  is too bad that Hawaii and Alaska are not included with this scripts yet.
Aloha,
--Stan Y.
   Maui, Hawaii
 --- Blitzortung ID: 993
 --- FlightRadar24 ID: F-PHOG1
WDL 6.05
MS Windows 7 Pro
Davis Vantage Pro 2+ Wireless
Webcam: Axis 211
Offline jmcmurry
  • Jim McMurry
Re: wxStory 3.0
« Reply #40 on: June 15, 2022, 07:31:45 PM »
I've updated the .zip in the first post to V3.07.  The map and script were updated after tracking WFO performance for over 3 months.  Basically, Reno turned yellow.  - Jim
Stan, I'd love to add those sites if they ever participate.
Offline Silversword
  • --Stan Y.
Re: wxStory 3.0
« Reply #41 on: June 16, 2022, 12:57:27 AM »
Thanks Jim for the update and hope one of these days the NWS office here will participate as well as Alaska.
Aloha,
--Stan Y.
   Maui. Hawaii
WDL 6.05
MS Windows 7 Pro
Webcam: Axis 211
Offline hunter362
    • Fairmount Hill's Weather
Re: wxStory 3.0
« Reply #42 on: June 28, 2022, 10:52:22 PM »
Jim, I've got a similar issue with the map being drawn, here's the error I'm getting:  [ You are not allowed to view attachments ]
Unable to open  './images/Ws_map_bgm.png' for writing: Permissiom denied in wxStory_inc.php line 158
permissions are 644 on the images
Viewing source I get a 404 error
!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /images/WS_map_bgm.png was not found on this server.</p>
</body></html>
What am I missing here?
« Last Edit: June 28, 2022, 10:54:20 PM by hunter362 »
Offline jmcmurry
  • Jim McMurry
Re: wxStory 3.0
« Reply #43 on: June 29, 2022, 05:52:45 AM »
Bill,
I'm running the script on two different servers and the images are 0644 on both.  The images folder itself is set 0755, maybe you can check that?
Please post the url of the file that is including wxStory_inc.php, or upload weather-story-test.php So I can test from here.
- Jim
Offline hunter362
Re: wxStory 3.0
« Reply #44 on: June 29, 2022, 09:21:26 AM »
Jim,
Images folder is 0755, changed folders, changed all images to 0777, still get the same error
PHP 5.5.9-1ubuntu4.29+esm15 (cli) (built: Oct 27 2021 18:41:06)
http://www.camillusweather.com/weather-story.php
Offline 92merc
  • BismarckWeather.net
Re: wxStory 3.0
« Reply #45 on: June 29, 2022, 11:51:04 AM »
I'm not sure how the script works to pull my images, but they aren't showing.  I'm getting the headers correct, just not showing the pictures.
https://www.weather.gov/bis/weatherstory
https://www.bismarckweather.net/wxstory.php
Offline jmcmurry
  • Jim McMurry
Re: wxStory 3.0
« Reply #46 on: June 30, 2022, 06:51:45 AM »
Right now, I'm clueless as to why these two different problems are happening.  I suggest that we start by making sure we're all on the most recent version of the wxStory_inc.php script.  Version 3.07 is in the first post in this thread.
- Jim
Offline 92merc
Re: wxStory 3.0
« Reply #47 on: June 30, 2022, 08:44:29 AM »
I just re-downloaded and configured mine again.  Pictures are still MIA.
Offline jmcmurry
  • Jim McMurry
Re: wxStory 3.0
« Reply #48 on: June 30, 2022, 09:21:27 AM »
92merc, please try using a ftp program such as Filezilla and clear everything out of your wscache folder and see if that helps.
hunter362, any chance of creating a new images folder with just WS_map.png in it?
- Jim
Offline 92merc
Re: wxStory 3.0
« Reply #49 on: June 30, 2022, 09:34:51 AM »
527 files cleared from cache.  Issue persists.
wsdata_bis.php, wsdata_grr.php showed up after I tested the page.  Plus a couple of matching wsimg files.
