Weather Station Hardware => Oregon Scientific Hardware => Topic started by: frankben on February 11, 2020, 02:24:51 PM
Today I switched from Cumulus 1 to CumulusMX. All batteries in the sensors have been replaced and the station has been reset.
However, when I start CumulusMX, the reception of my anemometer data at the station stops, the data freezes! As soon as I close CumulusMX I see the data change again!
I already tried it on another laptop but it is the same. Anyone suggest what the cause might be?
Regards
Frank
I am not familiar with the WMR200, but does it now still run properly with Cumulus 1 or the same as CumulusMX?
Enjoy,Paul
it was running fine with Cumulus 1 on an old laptop with Win XP but that laptop past away.
The problem with CumulusMX is new!
I was just trying to see if something else might be causing the issue, therefore asking if now Cumulus 1 still works fine or has the same issue as CumulusMX. Looks like you've had some changes to your system so possibly that is causing issues.
I also think that something had changed because now it apparently works but due to the many changes I do not know why. :roll:
well it works. I'm happy. =D>
thanks for the effort anyway. [tup]
click on this link and search for "boigneberg"
https://www.awekas.at/en/map.php?map=cond (https://www.awekas.at/en/map.php?map=cond)
Great!
I was born in Heist-op-den-Berg...
