Author Topic: Help Please - WS80 Power / Heater  (Read 972 times)
Offline PCM
  • Newark Novice.......
  • Very New to this,
    • Highfield Weather
« on: December 30, 2021, 09:36:51 AM »
For Christmas I got a Ecowitt ws80 ultrasonic anemometer.
I also have the Ecowitt 12W Power supply which is a AED Power Supply Model AED12.......(Ecowitt extension leads are un-available at the moment.)
To connect the WS80 lead to the power supply I am missing a 2 pin male connector with a screw collar. The lead supplied from Ecowitt is bare wire at one end.
I am sure the connector is some sort of standard component but I am unsure what type / size I need.
If anyone could advise I would be grateful........
Cordially & Compliments of the season.......
Photos attached.......
https://pcmwx.com/
Ecowitt WS80 & Ecowitt WH40
Ecowitt GW1100A
CumulusMX & Utils
WU:INEWAR40
Offline Gyvate
Re: Help Please - WS80 Power / Heater
« Reply #1 on: December 30, 2021, 10:47:43 AM »
There are several posts/threads in the forum relating to this topic:
entering "ws80" and "heater" into the search field will give quite a few results
e.g. https://www.wxforum.net/index.php?topic=40977.msg422617#msg422617
And there are more - have a look ;)
The plug type is known as GX 12.
Offline PCM
  • Very New to this,
    • Highfield Weather
« Reply #2 on: December 30, 2021, 10:50:23 AM »
Many Thanks for taking time to reply so promptly..........I suspect my search terms were wrong..........
Cordially
https://pcmwx.com/
Ecowitt GW1100A
CumulusMX & Utils
WU:INEWAR40
Offline whitecitadel
« Reply #3 on: December 30, 2021, 12:11:32 PM »
The PSU is out of stock for a long time now as are the cables which is frustrating, I have mine to mount and I believe that the 12v also runs the sensor? (leaving the Lithium for emergencies only)
I am tempted to cut the connector off my sensor (but if I have any warranty issues could be a replacement) but I found some old 12v garden lights in the junk box the other day that look very close in connector type so I need to see if its a fit.
Offline G.Brown
« Reply #4 on: December 30, 2021, 01:29:38 PM »
I think they are Aviation plug/sockets - you can get plastic or metal ones.
https://www.ebay.co.uk/itm/123948544378?var=424738237484
Offline PCM
  • Very New to this,
    • Highfield Weather
« Reply #5 on: December 31, 2021, 03:31:36 AM »
Many thanks for that......the wonders of Ebay........I'll report back as to outcome.........
Cordially........
https://pcmwx.com/
Ecowitt GW1100A
CumulusMX & Utils
WU:INEWAR40
Offline PCM
  • Very New to this,
    • Highfield Weather
« Reply #6 on: January 07, 2022, 06:14:41 AM »
So just to confirm the connection to the power supply unit is NOT a GX 12 connection. The male 2 pin connection needs to be bigger than a GX 12.
What does work is an outdoor light plug and play lead. Part # 33789 made by "Green Lighting" and supplied by Toolstation here in UK.
Photos attached
Many Thanks
https://pcmwx.com/
Ecowitt GW1100A
CumulusMX & Utils
WU:INEWAR40
« Reply #7 on: January 07, 2022, 06:35:53 AM »
Thanks for sharing, that's a great find - just a shame its discontinued and mostly out of stock at toolstation everywhere!
The manufacturer website also is out of stock:
https://greenlighting.co.uk/product/extension-cables/
I did mention above I found a lighting product that looked the same, but as my WS80 was already up the pole I had not had a chance to check it.
Offline PCM
  • Very New to this,
    • Highfield Weather
« Reply #8 on: January 07, 2022, 06:44:54 AM »
You were 100% Correct.........just a post script.......the thread on the power supply unit differs to the thread on the extension lead.......silicone / heat wrap by way of a work-around.........
I got the last two in UK ( Toolstation Lincoln ) :eek:
Cordially......
https://pcmwx.com/
Ecowitt GW1100A
CumulusMX & Utils
WU:INEWAR40
« Reply #9 on: January 07, 2022, 06:48:58 AM »
Does the thread match on the WS80 end? I don't have the Ecowitt supply so will likely use another supply that is compatible.
I found some stock at another store about 15 miles away so that could be worth a weekend bike ride to stretch my legs and collect...
Offline PCM
  • Very New to this,
    • Highfield Weather
« Reply #10 on: January 07, 2022, 07:04:42 AM »
No it does not.........good luck......let me know how you get on...........when you collect make sure the female connection has both white liners...you will see from  my photo that one of the small nylon liners is missing.
Cordially
https://pcmwx.com/
Ecowitt GW1100A
CumulusMX & Utils
WU:INEWAR40
Offline G.Brown
« Reply #11 on: January 07, 2022, 09:51:49 AM »
Photos attached
Many Thanks
I'm a bit confused referring to your photos - you are trying to plug the socket part of the plug/socket together - you dont seem to have unscrewed the plug connection?
Also there are different sizes of aviation socket, the specifications are always quoted on the ebay offers - I think the next on up is a 18 and the plastic ones are also different - you need to read the specs in the description on ebay.
Offline PCM
  • Very New to this,
    • Highfield Weather
« Reply #12 on: January 07, 2022, 10:12:47 AM »
Many thanks for that. To avoid confusion you may wish to read my initial post, the issue is that I am unable to connect to Power Unit. Power unit is two pin and although previous correspondents suggest a GX12 as a solution that is not the case. The solution was to purchase a garden light extension lead which fits, and I am now able to connect everything up.I am sure a MX fitting would suffice and am aware that a variety of sizes are available from a number of retailers. To date no one has advised what size fits into Power supply.
Cordially
https://pcmwx.com/
Ecowitt GW1100A
CumulusMX & Utils
WU:INEWAR40
Offline Gyvate
« Reply #13 on: August 19, 2022, 03:11:16 AM »
Even though it's an old(er) thread - what may help in identifying the connector to the Ecowitt provided power supply (and a description of the socket there): https://www.wxforum.net/index.php?topic=40977.msg450478#msg450478
