Author Topic: VP2 Max. Temperature Sensors.  (Read 5353 times)
Offline wuhu_software
    • WUHU Software Yahoo Group
« on: September 29, 2006, 08:39:24 AM »
I was wondering if a VP2 expert could help me here.
I emailed Davis a couple of times and did not get a clear response.
The question is how many additional indoor temperature sensors can I add to a VP2 system that will be equiped with outdoor sensors?
The Davis first response was "You can have a total of four temperature humidity stations connected to each console. "
When I asked for clarification, the response was "Actually, you can have a total of 7 extra temperature stations.  Plus the station it self. "
So can anyone tell me how many sensors I can add to a standard Davis VP2 (that will have all the outdoor rain, temp/humidty, and wind sensors)?
Also, is there an integrated temp/humidity sensor in the console itself?
Thanks in advance.
Offline ncpilot
    • Monkey Junction Weather
« Reply #1 on: September 29, 2006, 10:08:53 AM »
From the manual:
The console can receive signals from up to eight transmitters total, but
there is also a limit on the number of certain types of transmitters. The
table below lists the maximum number for each type of transmitter:
Note: Listening to more than one transmitter may reduce battery life significantly.
Integrated Sensor Suite (ISS) 1
Anemometer Transmitter Kit 1
Leaf & Soil Moisture/Temperature Station 2
Temperature Station 8
Temperature/Humidity Station 8
That's where Davis got the "7" figure. You've already got the ISS, add 7 temp/humidity stations, and you're up to the max of 8 xmitters.
And yes, the console has a temp/humidity sensor.
If you had a wireless anemometer, then you could add only 6 more temp/hum. sensors...
Marc
Wilmington, NC
"Monkey Junction Weather"
Davis VP2 wireless, WeatherLink
« Reply #2 on: September 29, 2006, 10:52:48 AM »
Thanks for the information. I appreciate it.
You would not happen to have any information on the WeatherLink for Alarm Output module would you?
http://www.provantage.com/davis-instruments-6544~7DAVS059.htm
From what I have read, you can create recipes to fire the outputs based on existing variables (temperature, wind speed and direction, etc), but I was wondering if you could write custom software to fire the outputs?
Thanks.
Quote from: "ncpilot"
From the manual:
Offline ncpilot
« Reply #3 on: September 29, 2006, 11:28:27 AM »
Nope... but you could probably find the info on Davis' site--that's where I downloaded the manual and other stuff from...
http://www.davisnet.com/home_flash.asp
http://www.davisnet.com/support/weather/support_docs.asp?dtype=3
Third item from the bottom... "Using WeatherLink for Alarm Output with VP & VP2"
Marc
Wilmington, NC
