In the latest firmware update that screen has been changed to a simple drop down box. Entering values in thb0temp doesn't allow a change of anything greater than 68 Deg F. Something has been screwed up. I need to go to his forum and ask about this.
On the other hand I may just ignore it. I can't see why anyone would be interested in my indoor temp that I keep controlled with my thermostat anyway.
You should only enter the value you want to subtract or add :
not 68 Deg, only
-20 .
I am running the latest firmwares, also 1 on the beta friemware.
All show the same information.
If you post on the Metebridge forum also mention the firmware you are currently using.
Question already asked by @ConligWX did you use "CTRL-F5 " or similar just
to refresh the browserThat was warned to do that with the first version as the old html and new html got into a mixup.
Maybe you should try to re-download just to make sure.
And if there is a strange problem, it is never wise to continue with that version, replace with the latest install.
Wim
