Folks, Many stream feeds have been removed, either for '
no connection' OR '
no', or 'very
bad audio'.
NOTE: some receivers may have a 'quirk', and drop audio, after an 'alert' received... check your settings?. If yours is affected, re-activate, once you've corrected the issue.
IF your
local transmitter is
out of service, please re-activate your feed when restored.
For
any situation, use the contact form (
!important
!) at
https://noaaweatherradio.org/addstream/addstream.html ![Thumbs Up [tup]](https://www.wxforum.net/Smileys/default/thumbs-up1.gif)
On the NOAA Weather Radio Org website, we have available a couple of
monitoring utilities for download that may help with 'drop-out', depending on how applied.
Check out
https://noaaweatherradio.org/quality/monitor.html#monitors ![Thumbs Up [tup]](https://www.wxforum.net/Smileys/default/thumbs-up1.gif)
For daily reports, realtime analysis, history, and a
5 hour 'delayed' notification of loss of server connection,
providers can subscribe to Chappele Weather's Quality and Reliability on-line stream analysis platform.
https://chappelleweather.com/nwrorg/quality/tools/more-info.phpNOTE CURRENT SUBSCRIBERS: if your stream is one of those de-listed, you should re-subscribe to QRA Is a NOAA / WeatherRadio Canada live stream currently listed for your area?
or
Check Saratoga Weather's Station Lookup
https://noaaweatherradio.org/N2radio-finder.phpYou can provide a Weather Radio Stream... fairly simple... just sounds complex: everything you need to know is here:
https://noaaweatherradio.org/howto.htmlStay Save, Save a Life.
