Ηello guys,
I tested for 13 months 6153 model Davis VP2 24hrs fan aspirated unit with the new Davis Vue passive shield. They both installed on my terrace 8 metres from ground and 2,5 metres from terrace.
Maximum Temps: They had almost 0 dgrs Celsious difference at summer time and from 0,2 to 0,6 to the other autumn winter and spring time, with higher Temps in the passive Davis Vue shield. Its very clever that Davis put the sensor on upper place of plates under the big plastic base of weather station. So even in winter and less autumn and spring the sun angle is lateral and hit the plates for some hours ,its ''cost'' only some tens of degrees. I think that the VP2 passive shield with sensor between the plates get more differences overall in a year.
Finally my big surprise was at summer time. My place is in a middle of a biggest plain of Greece, Larissa city. Its one of the hottest place in Greece with calm winds and foehn winds sometimes that push the temp over 42s Celsius. In this ''no windy'' place the diferrences at high temps was zero !!! June July and August.
Minimum Temps: Stable -0,2 to -0,3 Celsius degrees differences all the months with Davis Vue passive cooler. Its normal cuz the cool air and some humidity stuck on sensor at cold calm nights.
Relative Humidity was the same with 1-2% differencies some days.
Precipitation was almost the same at stable rain and light rain. At thunderstorms and high rain rated the Vue count more 5-8% than the Davis VP2 rain gauge.
Wind was slightly lower at Vue( mean daily and gusts). Generally till 40km/hr differencies was very small but over 45km/hr was significant.
All my test on my Blog but unfortunately is in Greek language.
http://www.e-meteolarissa.blogspot.gr/2012/05/vp2fan-aspirated-vs-vuepassive.htmlVassilis
Larisa, Greece
