..and how high is your 2nd floor? I mentioned an average of 18 to 20 feet for most homes...but it could be something else.
Ok so I have gathered this.. I am about 30 feet above sea level when you add it all up. With a difference of about around 1 hPa as an offset between Absolute and Relative pressure. These numbers are probably pretty close to correct. The all important question is we’re and how do I input those numbers in the meteobridge, ws2000, and ecowitt? If you could add a step by step tutorial i would really appreciate it.
Just to make the math work out better this is what I'm recommending.
Your total elevation that you should use for your station is 26 feet which is 8 meters.
Your Offset is then 1 hPa. This means that your Absolute and Relative pressure should differ by 1 hPa.
The Meteobridge is simple....you just tell it 26 feet.
Send email registration update to cwop-support@noaa.gov and let them know that EW8834 is going back to active status and that your elevation is now 8 meters (they need it in metric).
As for how to enter that into the GW1000 and the WS-2000 well it works out like this:
- First change Relative to be 1 hPa greater than Absolute.
- Then adjust Absolute up or down so that Relative gets bumped up or down by however much is required.
