Author Topic: WeatherLink  (Read 883 times)
Offline txweather.org
    • Texas Weather
WeatherLink
« on: May 17, 2019, 10:20:31 AM »
I just updated to version 6.0.5 and my WeatherLink Network and Network Upload is grayed out.
Any ideas what I am missing?
Online johnd
Re: WeatherLink
« Reply #1 on: May 17, 2019, 10:30:28 AM »
Do you definitely have a station correctly configured and actively receiving data from a logger?
Cambridge UK
    • Texas Weather
Re: WeatherLink
« Reply #2 on: May 17, 2019, 10:41:57 AM »
I believe so. I can download data and start the weather bulletin... Yet I cant setup weatherlink network nor internet upload even though I setup the internet connection.
Offline wvdkuil
  • Wim van der kuil
Re: WeatherLink
« Reply #3 on: May 17, 2019, 10:46:33 AM »
And you have the PC with Weatherlink connectied to an Davis USB logger?
Or do you use an WL-IP from Davis?
Wim
    • Texas Weather
Re: WeatherLink
« Reply #4 on: May 17, 2019, 10:56:55 AM »
Wim
Nether.
I am using a nano sd which passes through the data. When I did the setup the weather link found the pro2 no problem.
Offline wvdkuil
  • Wim van der kuil
Re: WeatherLink
« Reply #5 on: May 17, 2019, 11:08:54 AM »
Wim
Nether.
AFAIK one can only use an (original ?) USB logger to setup the account at WL.com and fill in the DID as received from WL.com
After the setup the usb logger is not needed anymore and any pass-through can be used.
But that was almost a year ago in the first weeks of the WL.com v2 website.
Maybe that has changed.
Wim
    • Texas Weather
Re: WeatherLink
« Reply #6 on: May 17, 2019, 11:12:33 AM »
Wim
Nether.
Wim
Ok so I have a usb logger, Ill dig it out from my stuff and see how far I can get. Thanks Wim.
Online johnd
Re: WeatherLink
« Reply #7 on: May 17, 2019, 12:58:37 PM »
I'm not sure it was anything to do with wl.com 2.0 directly. Wasn't the issue that local WL will only enable the Internet Settings etc menus if it sees a USB (or serial) logger connected. And once enabled then you can switch over to using the network logger and the menus stay enabled.
Am I remembering that correctly?
Cambridge UK
    • Texas Weather
Re: WeatherLink
« Reply #8 on: May 17, 2019, 01:16:30 PM »
There is a "way" around it. Lightmaster was able to help me. I am not too windows smart as I am a Linux person.... He got it to work for me. I guess you can say that the error was between the chair and the computer :P
Offline lightmaster
  • MB-HWS Template Dev
    • Baxley,GA Weather
Re: WeatherLink
« Reply #9 on: May 17, 2019, 01:20:48 PM »
Yes, you have to trick the Internet settings to show up when you don't use a USB logger, but thanks to a bug in the software you can set it to a serial connector without actually connecting a serial connector, setup your settings, then set it to connect to your MB's IP.
Offline wvdkuil
  • Wim van der kuil
Re: WeatherLink
« Reply #10 on: May 17, 2019, 01:22:13 PM »
Well that is the best and easiest solution possible  =D>
Offline havtrail
    • Haverford Weather Station
Re: WeatherLink
« Reply #11 on: May 17, 2019, 07:18:58 PM »
That's not a bug, it's a feature!
Rich K.
Onset HOBO RX2102 Cellular
Offline lightmaster
    • Baxley,GA Weather
Re: WeatherLink
« Reply #12 on: May 17, 2019, 11:30:33 PM »
Rich K.
Touché
That word looks very weird spelled out, lol
Hopefully they never fix this "feature". Now I just need to figure out how WifiLogger uploads to WeatherLink's site without this annoying software running 24/7.
    • Texas Weather
Re: WeatherLink
« Reply #13 on: May 17, 2019, 11:40:38 PM »
Rich K.
Touché
Now that would be something else!
Online johnd
Re: WeatherLink
« Reply #14 on: May 18, 2019, 03:31:16 AM »
Just enter the same DID and keycode you're already using for the local Weatherlink program and enable the uploads &'submit'! (Probably not a good idea to have both sources uploading at the same time though.)
Cambridge UK
Re: WeatherLink
« Reply #15 on: May 18, 2019, 06:02:49 AM »
Rich K.
Touché
It already does. Works flawlessly.
I just open WL once a week to download that weeks data and then shut it down.
    • Texas Weather
Re: WeatherLink
« Reply #16 on: May 18, 2019, 10:06:51 AM »
I think what he means is how is Wifilogger is doing it so he can do it on his own. Not how to get his wifilogger (He does not own one) working. :)
