Weather Station Hardware > Oregon Scientific Hardware
OS WMR968 Temperature/Humidity readings not showing
<< < (2/3) > >>
wrj47:
Were the ants in the batteries area at all? I looked at the sensor and there wasn't any indication of insects. There was some water in the the battery area when I opened it up, but the rest of the solar units are out there also and they are working. So you didn't have to replace your temp/humidity sending solar unit?
tbrasel:
No the ants trolled right by the C-clamp holding the solar/battery housing...on up the pole right by the horizontal arm for the rain gauge...then took aim on the temperature/humidity sensor I have housed in an aspirator. They had attacked a wasp nest inside the aspirator housing as well & I think this might have been the straw that broke the camels back...per say...when they attempted placing it piece by piece (wasp nest) inside the sensor. They were destructive little guys...but I guess in hindsight...more damage could have occurred.
wrj47:
Jerry:
Thanks for the info, I'll try looking at that after it stops snowing by us.
tbrasel:
Nice that yours is working again.
wrj47:
Jerry:
I tried doing that and it didn't work. I also tried connecting it to the other solar unit. Same results. Looks like the temp/hydro may be the culprit.
Greg_M:
The temp/humid sensors fail just because. I've been through 3 or 4.
The last one has gotten weaker and I had to move it closer to the 968. It's still working kinda.
I think OS equipment is not meant to be used outside.
On an optimistic note, I just found another rain gauge so I now have that working again after almost 2 years without. This number 3
[#] Next page
[*] Previous page
