Author Topic: AcuRite Access model 09155M  (Read 1755 times)
Offline dotcompals
« on: June 20, 2021, 12:37:23 AM »
Hi there,
I am using Acurite 5 in 1 weather station with Lightning detector.
Recently I purchased "AcuRite Access model 09155M" so that I can make my weather station online via MyAcurite / WU.
But when i try to add "AcuRite Access" to MyAcurite App/website, it is returning the following error -
"Device must be connected and reporting data to claim it. Please make sure the device is connected to your router and the status lights are blinking. "
Tried all the methods described here
https://support.acurite.com/hc/en-us/articles/360021589233--Device-must-be-connected-and-reporting-data-to-claim-it-Error
Can any of you help me getting this device added to MyAcurite please.
thank you
Offline worachj
  • Twin Cities, Minnesota
Re: AcuRite Access model 09155M
« Reply #1 on: June 20, 2021, 08:01:29 AM »
Not sure if India is a supported country. You could get it to work if you try setting it up for use in one of the supported countries, but then your times would be off.
"Please understand that currently AcuRite and it's (sic)products are only supported within the US, Canada, UK, and Australia.
See these threads for some background information.
https://www.wxforum.net/index.php?topic=33006.0
http://www.wxforum.net/index.php?topic=35625.0
« Last Edit: June 20, 2021, 08:04:16 AM by worachj »
AcuRite Atlas
KMNSAINT173
Offline daman
« Reply #2 on: September 20, 2023, 07:30:15 PM »
Hi there,
thank you
What was your fix?
KMIBADAX38
AcuRite Iris/AcuRite Access
Offline daman
« Reply #3 on: September 22, 2023, 03:42:12 PM »
Hi there,
thank you
What was your fix?
In case any future readers see this my fix was simply getting an Access compatible sensor so the access could pick it up and send data. the access needs to send sensor data to be picked up/registered for myAcurite page.
KMIBADAX38
Offline karss
« Reply #4 on: September 23, 2023, 01:36:49 AM »
I am not sure whether this information is of any help to you. I gave up on the AcuRite ecosystem when they killed the SmartHub. I have a 5in1 sensor with a display, instead of migrating to Access provided by AcuRite, I chose the WeeWX on Raspberry Pi route to send information to WU. For this you need a Raspberry Pi and have the WeeWX installation running on the RPi, just plug in the USB cable from the display to the RPi and the WeeWX will capture data from your 5in1 sensor and send it to WU.
