Author Topic: NOAA WEATHER RADIO  (Read 153159 times)
Offline Cutty Sark Sailor
  • Moderator
Re: NOAA WEATHER RADIO
« Reply #325 on: March 19, 2017, 08:39:21 PM »
« Last Edit: March 19, 2017, 08:41:18 PM by Cutty Sark Sailor »
Offline satcop
    • Clifton Virginia Weather
« Reply #326 on: March 20, 2017, 08:06:43 PM »
Two versions of the software now available:
The fully loaded version
With over 90 streams you may want to update , the latest version of the current script  you can see it in action  here .  As a reminder the code has 3 files, the main script, a select script and an include script.  I have them available via ?sce=view.  Please note that the select and include files are constantly updating as we add stations, or if stations change their url, so you may need to download updates of those from time to time to keep up.
The main file can be downloaded here , the select file can be downloaded here and the include file which really does all the work can be downloaded here .  To have the code start on your area weather station change the default callsign on the main page and move the selected=selected on the select page to the station that is your area from the one Sterling site here in northern Va.
The current version for the select and include files as of this moment.... is 170320A, the main file 170313C.
For those who only wish to stream their own stream there is the economy version.  This version has a user defined setup at the top of the page, it to is designed around the Saratoga template and it is one script rather than 3.  You can see it in action here and it can be downloaded here
Bob
« Last Edit: March 20, 2017, 08:09:23 PM by satcop »
Clifton, Virginia Weather
  • Moderator
« Reply #327 on: March 20, 2017, 08:34:45 PM »
Offline Maumelle Weather
    • Maumelle Weather
« Reply #328 on: March 20, 2017, 08:56:53 PM »
Is Chris at CBS down, or is it my feed?
Plus, I can't connect to the Icecast server there, either.
GR2AE, GR3, Cumulus
Offline satcop
« Reply #329 on: March 20, 2017, 09:01:15 PM »
Things seem to be working including your feed.
    • Maumelle Weather
« Reply #330 on: March 20, 2017, 09:10:40 PM »
Strange, but it's Monday. Could have been an AT&T thing, also. Who knows. Darn gremlins!!!
GR2AE, GR3, Cumulus
  • Moderator
« Reply #331 on: March 21, 2017, 11:36:19 PM »
« Last Edit: March 21, 2017, 11:40:02 PM by Cutty Sark Sailor »
Offline hankster
    • NFM Weather
« Reply #332 on: March 21, 2017, 11:58:18 PM »
Yea, that was an adventure! Had to update the sound card drivers to get everything to work.
Offline satcop
« Reply #333 on: March 22, 2017, 09:05:37 AM »
For those who downloaded the economy version, there was an annoying issue with the narrow Saratoga version that popped up.  If you previously downloaded that version please download again.
Bob
Offline heatcats
  • Pacific Cyclone and Tsunami Central
  • heatcats
    • My YouTube channel
« Reply #334 on: March 22, 2017, 01:00:03 PM »
Is anyone else having issues connecting to the wxradio.dyndns.org server? It seems to me as if it's completely down.
Kyle/heatcats
Pacific Cyclone and Tsunami Central (PCTC)
Facebook: www.facebook.com/TsunamiCycloneCentral
For heatcats...
YouTube: heatcats
Twitter: heatcats7
Facebook: heatcats7
Offline 92merc
  • BismarckWeather.net
  • Moderator
« Reply #335 on: March 22, 2017, 01:06:41 PM »
Yep.  Me too.  I was just coming on her to post the same.  Tried it both from my work and home networks.
Offline Mark / Ohio
  • Live from Mars!
    • Fairfield County Weather
« Reply #336 on: March 22, 2017, 01:24:25 PM »
Yep, unable to send or receive from him at the moment.
  • Moderator
« Reply #337 on: March 22, 2017, 02:13:57 PM »
Haven't been notified from CHRIS of any issues, but this just cropped up in the last half hour
...Stand by.
Mike
Offline 92merc
  • Moderator
« Reply #338 on: March 22, 2017, 02:46:15 PM »
Looks like it is back up.  I had to restart the Darkice service on my Raspberry PI.
  • Moderator
« Reply #339 on: March 22, 2017, 03:03:07 PM »
Yes... Some of the Encoders may now require a 'reconnect'... I think M3W will, not sure about some of the others as I had stopped the test streams... now, a good reason to leave 'em up!
Chris says connection issues resolved.
Mike
Offline hankster
    • NFM Weather
« Reply #340 on: March 22, 2017, 04:18:53 PM »
How much bandwidth is the average being used uploading? I came home from work today and my stream had stopped but I see the server was down so that's the reason why. But M3W was showing my upload was 250M bytes (is that big B or small b?) in what was maybe 15 hours time. Does that sound right?
Offline Mark / Ohio
  • Live from Mars!
« Reply #341 on: March 22, 2017, 08:50:08 PM »
16Kb/sec. X 60 (sec.) = 960Kb/min.
960Kb/min X 60 (min.) = 57.6Mb/hr.
57.6 Mb/hr X 15 hours = 864Mb uploaded
Think I calculated that right..   :-k
Offline tim273
« Reply #342 on: March 22, 2017, 09:30:51 PM »
If it helps, this is how much I've used this month on my Linode box, at 64kbs:
Offline hankster
    • NFM Weather
« Reply #343 on: March 22, 2017, 10:34:20 PM »
Thanks for the info. It's showing my bitrate at around 32kbs so a rough estimate in my head shows this is about right.
Offline Mark / Ohio
  • Live from Mars!
« Reply #344 on: March 22, 2017, 11:09:26 PM »
I forgot to divide by 8 to convert the Mb (bits) to MB (bytes)   #-o
So 32Kb/sec X 60 = 1.92Mb/min.
1.92Mb/min X 60 (min) = 115.2Mb/hr.
115.2Mb/hr. X 15 Hours = 1.728Gb/ 15hrs.
1.728Gbs / 8 (bits in a byte) = 216 MB/ 15hrs.
 UU
« Last Edit: March 22, 2017, 11:18:09 PM by Mark / Ohio »
Offline 92merc
  • Moderator
« Reply #345 on: March 23, 2017, 11:41:24 AM »
To whomever is in charge of of the list, could you do me a favor and correct the spelling of my city?  Bismarck has a C at the end of.  Named after Otto Von Bismarck. https://en.wikipedia.org/wiki/Otto_von_Bismarck
  • Moderator
« Reply #346 on: March 23, 2017, 01:49:53 PM »
I think John and Bob need to catch that on their scripts... far as I can tell Otto would be ok with the website itself...?
Offline 92merc
  • Moderator
« Reply #347 on: March 23, 2017, 02:10:27 PM »
I'm half German myself.  So I'm sure it's OK.  :-)
danke
    • Maumelle Weather
« Reply #348 on: March 23, 2017, 02:21:33 PM »
Got it corrected. Thanks for letting us know.
GR2AE, GR3, Cumulus
  • Moderator
« Reply #349 on: March 23, 2017, 03:05:48 PM »
danke
The spouse of 46 yrs is ½ German, ½ Polish... never know which half I'm listening to... :twisted:
