Author Topic: PWS with Air Quality  (Read 1364 times)
Offline davewatson
« on: January 04, 2020, 03:51:48 AM »
Hi All,
It appears that my current PWS (its an Australian Jaycar branded XC0370, which appears to be the same as the Fine Offset WH2900 http://www.foshk.com/Wifi_Weather_Station/WH2900.html) has died.
So in looking at my options, I was trying to find something to upgrade it with, but to also include air quality sensors (PM2.5, PM10 etc.) - now I know my Dyson air purifier has this capability, and my research shows a number of commercial options, but nothing integrated into a nice PWS.
Is there anything out there I've missed?
Thanks!
Dave from Canberra, Australia
Re: PWS with Air Quality
« Reply #1 on: January 04, 2020, 09:32:43 AM »
You could get one of these stations from Ecowitt:
http://www.ecowitt.com/weather_station/
HP2551
HP2553
GW1001
GW1002
GW1003
...and then add this optional sensor:
WH41 (add up to 4 of them)
http://www.ecowitt.com/wifi_weather/83.html
You can also buy one of those HP255x stations and add a GW1000 gateway console. Or you can do it the other way around and get one of the GW100x versions and then add the HP2551-C display console.
There are also other optional extra sensors you can get.
Offline Mandrake
« Reply #2 on: January 09, 2020, 11:25:52 AM »
Since you are in Auz you can also purchase the Ecowitt kit from the Australian Amazon store or from Ecowitt direct (www.ecowitt.com)
G1ZFO
Ecowitt GW2000 (Test)
Ecowitt WS90 Wittboy - Test
Ecowitt WH41 PM2.5 AQM Sensor
Ecowitt WN35 Leaf Moisture
Offline davewatson
« Reply #3 on: January 10, 2020, 01:03:58 AM »
Hadn't considered Amazon! - great idea thanks!
Offline KablammoNick
« Reply #4 on: April 30, 2020, 10:06:44 PM »
Which setup did you end up going with Dave?
My BloomSky's temp sensor has finally gone the way of the wind & UV sensors, so looking for something to replace it with, but can't justify the coin of a Davis system.
-Nick
Offline davewatson
« Reply #5 on: April 30, 2020, 10:10:17 PM »
-Nick
Unfortunately never got to get one - my system has continued to work OK since we had the hot temps - I suspect that next summer it will play up again though, and hopefully there will be a bigger range of options on the market!
« Reply #6 on: April 30, 2020, 10:16:52 PM »
-Nick
Bugger.
Leaning towards the GW1001 purely as the inside display is through Home Assistant anyway.
