Author Topic: PWS not searchable on Wunderground  (Read 735 times)
Offline weathermanslj
« on: January 22, 2024, 07:08:38 AM »
Hi All,
I’m new to the forum here.  I have a PWS registered at Wunderground with the station ID of KKYGEORG112:  https://www.wunderground.com/dashboard/pws/KKYGEORG112
Even though the station is clearly public, I can only see it by typing in the url.  I can’t find it by searching the station ID in the app.  Moreover, when I try to search for KKYGEORG112 using the Wunderground app or in a browser, the station KKYGEORG62 comes up, which is what the station ID used to be before I moved and re-registered it.  And clicking on KKYGEORG62 doesn’t show any data.
I can see the station on the map, but clicking on it and attempting it to favorite isn’t working.  Any help would be appreciated, since I would like to open the Wunderground app on my phone and have it go directly to my PWS.  Do I need to delete the device and re-add it??
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
Re: PWS not searchable on Wunderground
« Reply #1 on: January 22, 2024, 06:56:39 PM »
Some pages stored in a memory cache may cause similar issues.
And sometimes these things work fine after being on line for some time.
« Last Edit: January 22, 2024, 06:58:53 PM by davidmc36 »
« Reply #2 on: January 23, 2024, 08:04:40 AM »
Do you mean that it might be a local device (e.g. phone, ipad) problem - pages stored in a memory cache there?  The problem does persist across multiple devices.  And the PWS has been online in this manner for probably a month now.  How could I clear the memory cache, if that is indeed the problem?
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #3 on: January 23, 2024, 09:20:01 PM »
Maybe one or two devices with same cache is plausible but not over several.
Strange. I can search it in mobile browsers.
Same search issue you have in the app.
When I scrolled the map in the Android App, and clicked on the station, and chose View Forecast, it was then visible in my Favorites/Recents list. I tapped the star and made it a favorite.
« Reply #4 on: January 24, 2024, 07:06:50 AM »
Thank you for your response.
I had the same search issue on a laptop device, but I was able to see the station on the map and add it as a favorite.  I found that if I deleted the app on my iPhone and iPad and then re-installed it, the issue was resolved.  I still can’t search the station using the search feature (KKYGEORG62 still pops up, but not KKYGEORG112), but I could favorite the station by finding it in the map.  I don’t dare click on the KKYGEORG62 station from the search, because I’m afraid that will mess things up again.
Thank you for your help!  I think I’m good to go now.
Offline davidmc36
  • FN25ie61jw
    • MorewoodW34
« Reply #5 on: January 25, 2024, 05:18:48 PM »
62 was "Greyed Out" when it popped up in search. Dead Click
Offline wags1
« Reply #6 on: January 27, 2024, 09:46:37 AM »
I have had the same problem with my PWS (KPAKUTZT35) for well over a year now. I have found no way to fix the issue. WU has gone significantly downhill since IBM took over IMO.
Offline 92merc
  • BismarckWeather.net
« Reply #7 on: January 27, 2024, 11:38:07 AM »
And IBM sold WU to an investment company this summer...
