Author Topic: Vantage Vue Console logger pinout  (Read 160313 times)
Offline SpartanWX
Re: Vantage Vue Console logger pinout
« Reply #25 on: March 05, 2011, 11:47:30 PM »
Cost?  Experience required to cobble this together?  Sounds intriguing.
Offline af4ex
  • Palm Bay, Florida (EL98PA)
    • Willard Road Weather
« Reply #26 on: March 06, 2011, 08:22:12 AM »
@SpartanWX
So far less than $100, as promised, but you have to be experienced with the soldering iron and circuit construction. Yes, intriguing because these XBee devices are really amazing: postage-stamp sized 2.4GHz modem transceivers that transparently extend serial connections throughout the house!
My 1-milliwatt pair have now been chugging away for about 16 hours now without a hiccup, delivering my VUE station reports to APRS/CWOP. :-)
Here's how I did it. First, the easy part.
Buy a USB EXplorer ($25) and a 1mw XBee ($22) from SparkFun, plug it into your destination computer, configure it, and you're halfway done! (You can use a higher power unit of course, but more expensive and higher drain on batteries)
http://www.sparkfun.com/products/8687
http://www.sparkfun.com/products/8665
[You can probably get these slightly cheaper if you shop around, but I just got everything from SF for convenience of the their excellent support]
This is what it will look like when it's running. The red/green status lights are nice, green blinks whenever a record is received wirelessly from the VUE console!
Now the console-side transceiver. Good news: it will be cheaper because we'll build it from inexpensive parts, plus another $22 XBee Modem. But it will of course be more difficult to put together. Don't attempt this unless you have a fine-tipped soldering iron and some building experience.
We'll use the SparkFun XBee breakout board ($3) and a pair of 2mm header sockets ($1 each) which need to be soldered to the breakout board for mounting the XBee transceiver ($22, same as above). Buy an extra header socket, which will be cut up to make the console connector cable (details in previous Phase I posting).
http://www.sparkfun.com/products/8276
http://www.sparkfun.com/products/10030
You'll also need some 0.1" spacing PC board (PCB) and a six-pin 0.1" header for the console connector. I had some of these pieces laying around, but you can get them at SparkFun or Radio Shack. Typically you buy oversized pieces and cut them to size. Shouldn't cost more than a few bucks I would guess.
So here's a Radio Shack PCB which I hacked down to size and mounted the XBee breakout board and the 1x6 header socket for the console connector cable
After laying out the PCB you'll need to flip it over and make the connections from the XBee pins to the console header socket
Vcc -> Vcc
Gnd -> GND
Dout -> RXD0
Din <- TXD0
Note that TX _output_ goes to XBee _input_ etc. Most common wiring errors occur here. Also be careful with the soldering iron. It's incredibly easy for solder to "bridge" across pins if you're not careful. Inspect all work with a magnifier before applying power!
Note that the header socket uses the same ordering from DeKay's original design, so that the same connector cable can be used for both the wired and wireless versions (Phase I and Phase II)
[Have I mentioned that without DeKay's intrepid research, none of this stuff we're doing would be possible? We love you, DeKay!]
The final hardware step is to build the connector cable, essentially the same cable as constructed in Phase I. If you've done this then all you have to do is connect the red wire to the Vcc 3v connection and you're ready to go. (Don't forget the shrink wrap. I'll guarantee short circuits if you don't use it. Cheap to buy (Radio Shack etc) and easy to apply (hair dryer etc)).
The last step is to configure the XBee modems for operation at 19200 baud. The default setting is 9600 baud. Download the excellent X-CTU  utility from Digi Corp to do this.
http://www.digi.com/support/kbase/kbaseresultdetl.jsp?kb=125
Just plug the XBee's into the USB explorer and run the utility to set baud rate (also you can check out other parameters with this tool).
[added 15-Mar: More detailed XBee instsructions and troubleshooting here: http://www.instructables.com/id/Changing-Xbee-Baud-Rates/#step1
Now you have a pair of transceivers. Plug the USB explorer into your destination computer and the homebrew unit into your console using the console connector.
Enjoy!
Next on the agenda, discussions about Phase III, custom PCB for making this available to the masses.
John/af4ex
« Last Edit: March 15, 2011, 07:37:00 PM by af4ex »
SOFTWARE: weeWX, APRSISCE
http://www.qsl.net/af4ex/wx
Offline DeKay
    • Mad Scientist Labs
« Reply #27 on: March 06, 2011, 10:44:23 AM »
=D&gt;
Awesome job and, better yet, a very detailed writeup that others could follow (I know those take a lot of time to put together).   It is great that others are going to be able to do this without removing a single screw on the console.  I'll put a link to this on my blog if you don't mind.
Have you determined if there will be an impact on console battery life by connecting up to Vcc rather than DC In?  Maybe a switch or a jumper so you could easily choose between one or the other?
Offline af4ex
« Reply #28 on: March 06, 2011, 12:07:15 PM »
@DeKay
> ... Have you determined if there will be an impact on console battery life ? ...
Not yet, the XBee specs say it consumes 50ma @ 3.3v, which translates into 0.165 watt power consumption overall. It does indeed run on battery power (I tried it), but 50ma probably will cut the battery life in half (disabling the 3 LED's on the USB explorer [on the computer side] would help a bit). But I plan to run it from the wall wart most of the time.
I'm going to put a quick-disconnect plug in the 3.3 volt  line on the cable so that I can insert an ammeter and do some direct measurements to verify power consumption. Also will allow disonnecting the power if I want to use it with USB-COM interface (where it is internally USB powered). I did run it on the USB-COM with the extra 3volt line connected and it worked fine. But I think it would be safer to disconnect the power if you're not using it. You don't want two power sources bucking each other (in case one shorts out etc).
I should make it clear that the console cable is a kluge, with those 2mm plugs hacked out of an XBee socket. Difficult to make and install, but it works and avoids having to open the case, as you pointed out.
Is it worth making this thing? Sure, if you have the skills. It will probably be a month or so minimum before we have a custom board designed and available. I would like it to have both an XBee and a USB connector so that it could be used wired or wireless. It will have a custom 2x10 socket to plug right into VUE console.
The idea is to produce a PCB that will be much simpler to construct for beginners and perhaps, if there is a demand, have some ready-made units for sale. (Hurray, I can quit my day job!) :-)
But there will be some design issues to solve. What features are needed? Let me know. I have virtually zero experience in the hobby weather arena.
I've designed a couple of very simple circuit boards years ago, but none as complicated as this will be.
So ask questions and tell me what features you'd like to have. Then I'll decide what I can do (or perhaps find someone more experienced to help out). [SparkFun, are you listening?]
John/af4ex
« Last Edit: March 06, 2011, 12:20:22 PM by af4ex »
Offline af4ex
« Reply #29 on: March 06, 2011, 12:37:09 PM »
You're probably wondering why I didn't use 2x10 header receptable with 2mm pitch, instead of the kluge plugs?
Well, they're hard to find (because 2mm is not very popular). Samtec makes them for $2.75 each, but the minimum shipping is $10. So, not wanting to go over my $100 budget (and also being cheap) I decided to make my own. :-)
Digikey carries it too, but they were out of stock, so I didn't want to wait on a back order.
Here's the spec. If anyone can find a good source ("cheap") for these, let us know. It would be much easier to build this plugin using this receptacle:
Samtec Part #:ESQT-110-02-G-D-760
 ("2mm elevated pin header")
http://www.samtec.com/ProductInformation/TechnicalSpecifications/Overview.aspx?series=ESQT
http://www.samtec.com/SuddenService/OnlineOrder/OnlineOrder.aspx
John/af4ex
« Last Edit: March 06, 2011, 12:41:13 PM by af4ex »
Offline Garth Bock
  • Table Rock Lake Weather
« Reply #30 on: March 06, 2011, 01:28:47 PM »
Ok my head is reeling a bit. You mean to say I could, with your setup, uncable my Envoy from my weather computer and have it stream the serial data via Zwave or Zigbee and have a wireless receiver at the pc to receive the data ? I could put my Envoy where I want and the computer where I want ? Why isnt Davis thinking of this ? You are doing one heck of a job !!!! =D&gt; =D&gt; =D&gt; =D&gt;
Offline af4ex
« Reply #31 on: March 06, 2011, 01:45:05 PM »
@Garth Bock
> Ok my head is reeling a bit. ....
I'm not sure what an Envoy is, but sounds like some wireless gadget. Yes, my circuit would replace that and the WeatherLink also. Plugs into the 20-pin socket at the bottom of the VUE (I'm told the VP2 has a similar connection). Then, acting as a virtual COM port (COM4 etc), allows a computer in range to see the remote console as a local serial device. So far it has been totally 'transparent' to the functionality of WUHU and CUMULUS, the only two programs I have tried.
I'm a complete newbie at this weather game, but am handy with the electronics. And, yes, Davis is perfectly welcome to take this design and make it into a commercial product to fill that huge gap in their product line ("low-cost wired/wireless serial interfaces"). Hopefully, with a price tag around $99.95 (wireless) or $29.95 (wired).
 :grin:
« Last Edit: March 06, 2011, 02:49:03 PM by af4ex »
Offline mmorris
  • Hope your day is full of sunshine
    • Weather and Racin
« Reply #32 on: March 06, 2011, 01:57:36 PM »
Nice device but if your sending data to WU and your computer has to be shut down there is always a reason your device has no way to send the data so there will be gaps. Unless you put in a logger. The wireless looks interesting. I suppose If you got WeatherLink data logger all ready you could integrate that into sending that data wireless also,
Follow me on twitter
Quadruple Bypass survivor
Offline DeKay
« Reply #33 on: March 06, 2011, 02:01:34 PM »
Here is the Envoy manual.  Looks to me that the same solution applies, looking at Page 4 of the document.
af4ex: It looks like Digikey has a few headers in stock now (6) for the outrageous price of $5.13.  Look here.
Offline af4ex
« Reply #34 on: March 06, 2011, 02:24:34 PM »
@mmorris
Actually, I've got that situation partially covered. I'm using a "discarded" Eee PC notebook (with a damaged LCD screen) as my weather computer. Uses a solid state drive, has WiFi within the house, and can run for about 6 hours on battery backup. So it looks like I will be dedicating it to weather related tasks, and will rarely need to shut it down (once I'm all set up).
So far I've been able to keep it going for 5 days now, even while developing this wireless interface.
« Last Edit: March 06, 2011, 02:36:19 PM by af4ex »
Offline af4ex
« Reply #35 on: March 06, 2011, 02:33:46 PM »
Says here the Wireless Weather Envoy has been discontinued. Is there a replacment?
http://www.davisnet.com/weather/products/weather_product.asp?pnum=06314
Offline dalecoy
    • Lee's Summit, MO
« Reply #36 on: March 06, 2011, 02:35:33 PM »
The regular Envoy is essentially a VP2 console without a display.
Offline dalecoy
    • Lee's Summit, MO
« Reply #37 on: March 06, 2011, 02:37:39 PM »
« Last Edit: March 06, 2011, 02:40:38 PM by dalecoy »
Offline af4ex
« Reply #38 on: March 06, 2011, 02:42:09 PM »
@mmorris
> sending that data wireless also,...
I don't plan on buying a WeatherLink. That was the motivation for building this replacement. I could write my own logger I guess. Right now I'm letting APRS/CWOP do my logging. I suppose that will change as I learn more about these personal weather stations.
 :grin:
Offline mmorris
    • Weather and Racin
« Reply #39 on: March 06, 2011, 02:52:07 PM »
@mmorris
 :grin:
Just another aspect of the hobby your having fun that all that counts, I've enjoyed readin the thread  =D&gt; I myself already own a serial data logger wired so I don't plan on using your project. Keep lookin forward.
Offline d_l
  • Slide Mtn - Mt Rose
« Reply #40 on: March 06, 2011, 03:05:43 PM »
That was a VP1 Envoy page, not a VP2 version.
--Dave--
Offline lobolobo
« Reply #41 on: March 08, 2011, 08:24:00 AM »
First of all say hello to everyone from Madrid (Spain - Europe).
@AF4EX and DeKay
Second, congratulations and say thank you to AF4EX and DeKay for the information about the pinout of Davis port. Simply fantastic, very instructive, and very interesting.
I´m quite confused about one thing in this post. I read all about the XBee here and i feel quite confused about one thing. In the Breakout Board for XBee Module DOUT means Tx an DIN means Rx, so, if this is correct (only if this is correct), what about the photo in what we can see the wire connections? It´s labeled correct? In AF4EX´s photo, you labeled de green color wire like Rx, is this correcto or it would be Tx? Same with the blue colored one. I said that because of the XBee pins distribution (PIN 1= VCC or POWER. It would be 3,3v or so i think. PIN 2= DOUT (Tx), PIN3= DIN (Rx) ... etc)
@DeKay
In the other hand, another doubt is, what are TxD1 and RxD1 (in the console port) for? Can we use them for something special. Sorry about my ignorance.
I will try to make this project to connect mi Vantage Pro (the original, the VP1) to my computer in order to use some kind of special and compatible weather software like Cumulus or something like that.
Thanks in advance for your requests and again, congratulations.
(Sorry about my english)
« Last Edit: March 08, 2011, 08:44:12 AM by lobolobo »
Offline af4ex
« Reply #42 on: March 08, 2011, 10:32:22 AM »
@lobolobo
Yes, it's correct, but I should have clarified more that the labels 'RXD0' and TXD0' refer to the _destination_ pins on the 20-pin connector.
So the XBee _output_ goes to the 20-pin _input_ etc.
Vcc -> Vcc
Gnd -> GND
Dout -> RXD0
Din <- TXD0
FYI, my 1-milliwatt wireless XBee's are still running and sending data to APRS/CWOP, from downstairs to upstairs, about 20 feet direct path, through the ceiling. I carried the laptop around the house  and found that the signal starts to fade at about 40 feet and going through several walls. There's a range test function in X-CTU for measuring signal strength etc, but I haven't used it yet. For 10 or 20 feet there doesn't seem to be any range issues. If you have to transmit further than 30 ft or so, through several walls etc, then you may to need use the 60mw transceivers.
Hope that helps,
John/af4ex
« Last Edit: March 08, 2011, 11:19:22 AM by af4ex »
Offline DeKay
« Reply #43 on: March 08, 2011, 11:10:36 AM »
I don't know what they are for.  They don't spit out anything during a console reset, and they don't respond like TxD0 and RxD0 do.  It could be they are there for factory testing and that there is some hidden command to wake it up.  Or maybe they were brought out to the expansion port "just in case" but never used.  It would probably take a deep dive into the firmware to figure it out.  Nothing I'd be interested in, because all the good stuff you'd ever need is already on TxD0 / RxD0.
Using them for "something special" would mean you'd have to change the firmware to make it happen.  Not impossible, but pretty hard without the actual Davis code.
Offline lobolobo
« Reply #44 on: March 08, 2011, 12:01:30 PM »
@DeKay and af4ex
Very grateful for your requests.
OK, now I see it. Understood.
May be a detailed photo sowing the Vantage Vue expansion port with the wires conected would be very interesting.
OK, i got it. Thanks.
I will continue visiting this post with great interest.
Thank you very much.
« Last Edit: March 08, 2011, 12:27:03 PM by lobolobo »
Offline af4ex
« Reply #45 on: March 08, 2011, 02:12:08 PM »
@lobolobo
Good idea. Here's DeKay's pinout diagram, showing where the 2mm sockets are plugged in:
Maybe this will help to eliminate some confusion about the wiring.
Muchas gracias!
[Edit: I also inserted this figure into the main writeup above]
« Last Edit: March 08, 2011, 03:13:15 PM by af4ex »
Offline lobolobo
« Reply #46 on: March 08, 2011, 03:12:16 PM »
Muchas gracias a usted caballero ...  =D&gt;
Offline SpartanWX
« Reply #47 on: March 08, 2011, 11:28:24 PM »
@mmorris
 :grin:
I have a weatherlink with serial output.  As I understand it you are eliminating the weatherlink from the equation, which is cool.  However, I'd like to retain it for its logging capabilities should the WXPC go down.
In the very near future me and my VP2 will be relocating to a townhouse somewhere in the DC burbs.  Methinks that they're not going to be to keen on me slapping a weather station in the side yard.  I plan on finding a surrogate house in the area to foster my setup.  Wireless transmission between the serial weatherlink and the netbook is going to practically be a necessity.
Offline af4ex
« Reply #48 on: March 09, 2011, 06:47:37 AM »
@SpartanWX
You face a problem common to ham radio operators, who are similarly restricted on setting up antennas. (But we're pretty good at constructing antennas that look like flag poles, or out of nearly invisible magnet wire)  :grin:
Digi makes higher power  XBee chips, which SparkFun says have a range "up to 15 miles". But they don't mention you'd have to set up an outdoor antenna system to get that range. It's still only 100 milliwatts, less than those 1/2 watt Citizen Service walkie talkies.
http://www.sparkfun.com/products/9085
A more practical solution would be to pipe the data over the internet. It's only 19.2K baud so a regular high-speed cable should have the bandwidth.  There's probably remote logging software available to do that or you could write your own. Conceptually very simple, just set up a two-way socket (IP address + port number) and read and write to it like a file.
Or if you would settle for 'near real-time' performance, just spool the data to a file, and do a file transfer several times a day.
I finally got Cumulus working, so have switched to that from WUHU. It seems to have some logging capabilities. At some point though, I'll start writing my own software, once I figure out what I want to do with the data.
John/af4ex
« Last Edit: March 09, 2011, 07:34:17 AM by af4ex »
Offline SpartanWX
« Reply #49 on: March 09, 2011, 09:36:15 AM »
@SpartanWX
John/af4ex
I intend on communicating the data over the internet... but I need a means of communicating the data wirelessly from the console (which receives the data from the external station wirelessly) to the computer that is going to spit the data onto the internet.
Right now I have a clever arrangement with an end table that hides the PC and all the associated cabling and connections to the console.  At someone else's house I am at their mercy.  They may allow me to put the console somewhere where they are able to view it, but the PC might have to be in the closet or basement.  I need to transmit the data from the serial connection on the logger at the console, wirelessly to the serial connection on a PC which will be connected to the internet.
