Author Topic: Does your HP10 get very hot?  (Read 516 times)
Offline Wxbeginner
« on: February 28, 2024, 12:03:08 PM »
I attempted to install the HP10 garden cam this morning but can't get it to go into wifi setup mode. You are supposed to push down the camera button for 5 seconds then a light is supposed to flash so you can pair your wifi. Never get a flashing light and the camera gets very hot.
Did they send me a bad one? I tried the reset button but no change.
Thanks.
HP2560 (2), WN1980, GW1100, GW1200, GW2000
WS90(2), WS68, WH57 WH51-Orange Tree, WH51-Lemon Tree, WH51-Grape Fruit Tree, WH40, HP10, AC1100, WFC01
Ambient WeatherBridge
Offline Wxbeginner
Re: Does your HP10 get very hot?
« Reply #1 on: February 28, 2024, 06:10:36 PM »
It ended up getting so hot that it was starting to burn my hand. Unplugged and let it cool for awhile. When I turned it back on I got a red light for the first time. Did not get hot anymore but still would not go into setup mode.  Amazon has already sent out a  replacement and it should be here on Saturday. I have already read reviews on here that these camera's are not all that great but figured it would be fine for garden cam and hopefully it will.
Offline nordos
« Reply #2 on: March 01, 2024, 05:19:19 AM »
Simple and cheap hardware.  And just as easy to install and use.  This is what makes the Ecovitt camera so attractive.  I also ordered, but from Aliexpress.  The parcel is still on the way.  I hope to install a camera on the pier overlooking the river by summer.
Ecowitt HP2560, WS90.
river Norilskaya (city Norilsk)
Ecowitt: https://www.ecowitt.net/home/share?authorize=8NN7J3
WeatherCloud: https://app.weathercloud.net/d6797820927
Offline Rover1822
« Reply #3 on: March 02, 2024, 02:55:58 PM »
Yeah, I hope a new unit overcomes the issue, too hot to hold is not good, although interesting. I would have expected the power supply to crap out before the actual unit got to hot. But, never know
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Wxbeginner
« Reply #4 on: March 02, 2024, 04:25:20 PM »
Yep it came in today and no issues- went into pairing mode on boot up.  Barely gets warm now and working great on my test desk.
Will mount by "her" bedroom window so I can get a view of backyard patio where the orange tree & lemon tree currently reside. USB power cable via the window as I already have  the window setup for ham radio cables.
What would be fun for one day is to mount on my chimney and power the camera with a large usb battery and have it on a solar cell. I know wifi is greedy for power so it might not work but I live on a steep hill and get great sunsets.
Offline roferfruitfarm
« Reply #5 on: March 29, 2024, 02:15:20 AM »
Hi, were you able to set it up? Had the same problem from my HP10 order. Requested for a replacement and they said they will send an email once it’s shipped. Can I see the updated setup you had, including how it’s placed to the usb socket? Hope to have a better unit soon!
Offline Wxbeginner
« Reply #6 on: March 29, 2024, 02:31:11 PM »
yes I got a new one and it does not get hot. However, it did have an issue where it was periodically shutting down. I think it's a problem with the power connector but has not done it since since I used duct tape on the connector as a strain relief.
Now if I could get the wh57 to stop giving out false lighting strikes ever few hours thngs would be perfect for me.
Good luck. .it's a nice camera just be sure you realize it is a time lapse garden camera, not a streaming camera.
« Last Edit: March 29, 2024, 03:08:53 PM by Wxbeginner »
Offline Platokidd
  • top side land of Lincoln
« Reply #7 on: March 30, 2024, 08:09:04 AM »
Suggest you start a new thread for the wh57 lighting false reads. You could also search the foum. There are many threads on the false reads.
Ambient
1-WS-5000 1-WS-2902A 2-WS40/RAIN 1-WH31L
1-METEOBRIDGE 1-PM2.5 (WH41B) 3-WH31 1-SRX100LX
ECOWITT
2-HP2550 2-HP2560 2-GW2000 2-GW1100
2-WS68 1-WS80 1-WH32EP 10-WH31 1-WH40
1-HP10 2-WH45 4-WH55 5-WH51
1-WN30 1-WH41
1-DAVIS 7714
1-STRATUS
1-Fisher Barometer 1436R-22
PWS at 2 locations.
1- Storm Sensor-Zelda the dog ;)
Offline Wxbeginner
« Reply #8 on: March 30, 2024, 01:12:20 PM »
I'd love to get this fixed if I could. Moved it around the yard at different settings all week. About to try behind my shed and if that doesn't work - try it inside.
