Author Topic: Update WiFiLogger v1 from Firmware v1.24 to 2.38  (Read 627 times)
Offline chsgas
« on: March 04, 2022, 09:54:00 PM »
I can't seem to get a firmware update to work on my old v1 WiFiLogger.  I currently have firmware v1.24.  I downloaded the WiFiLogger v1 2.38 firmware.  I point the update to the "WiFiLogger_238.bin" file but keep getting the message "update failed restarting".
I read a support document that was posted on the internet stating that you needed to update to a version 1.24S before updating to a v2.xx firmware.  Is this correct and where can I find the v1.24S firmware.  If not, does anyone have a suggestion?
Thanks!!
Offline jcookjr82
Re: Update WiFiLogger v1 from Firmware v1.24 to 2.38
« Reply #1 on: March 04, 2022, 10:33:18 PM »
Here is the direct download link. Be sure to read the document before updating to avoid any issues. Once you have this update installed, you can run an update check from the actual WiFi Logger settings and update to v2.38.
https://wifilogger.net/files/WFL_Update_200.zip
Davis Vantage Vue (Brentwood, CA KCABRENT8 and Arnold, CA KCAARNOL99)
Davis Vantage Pro2 (Lakehead, CA KCALAKEH52)
LaCrosse 2813 (retired 1/17/2018)
