Author Topic: HP2551C WiFi exclamation mark!? No Ecowitt upload  (Read 426 times)
Offline wardie
« on: April 10, 2021, 02:19:59 PM »
Hi please help / any ideas. My Froggit HP1000SE / HP2551C console just stopped transmitting to Ecowitt. On the screen my WiFi signal shows as full bars and the config page says “Connected”. But there is a tiny exclamation mark to the left of the signal strength meter I’ve never seen before...
The console appears on my WiFi network, has an IP address, The same IP address appears in the console settings on-screen. I can ping it. WS View finds it as normal, and when I go into the web services on WS View it looks active the Ecowitt.net. The “response time” yields normal ing values in the 600-700ms range.
V1.7.1 firmware & EasyWeather v1.5.8
Ive tried rebooting the console and the WiFi router. I’ve tried (painfully) removing and re-entering the WiFi details on the console. Same result.
I also have 2x GW1000’s operating normally too and uploading to Ecowitt from my home IP network via same WAN.
Any ideas?
Froggit HP1000SE Pro-C console (HP2551-C)
Froggit HP1000SE Pro ultrasonic multi sensor with Ecowitt EC0002 heater (WS80)
Ecowitt Anemometer 5-in-1 array (WS68)
Froggit DP80 rain gauge (WH40) with spikes
Froggit indoor temp/humidity/pressure (WH32B)
Froggit DP50 Internal temp/humidity x2 (WH31)
Ecowitt Outdoor temp/humidity & RS-00001 shield (WH32)
Froggit DP200 PM2.5 outdoor (WH41)
Ecowitt indoor CO2 PM2.5 PM10 (WH45)
Froggit DP100 soil moisture (WH51)
Froggit DP60 Lightning detector (WH57)
Froggit DP1500 server dongle (GW1000A) x2
Raspberry Pi 4 / WeeWx-GW1000 API interface
WU: IKNEBW2
Offline wardie
Re: HP2551C WiFi exclamation mark!? No Ecowitt upload
« Reply #1 on: April 10, 2021, 03:02:14 PM »
Panic over. Another reboot of my router and also cable modem (not the wireless access point) did the trick. I’m guessing that little exclamation marks means it can’t connect to WAN even it if can connect to LAN. I dnd’t try any other web weather services to see if that was true or it was just Ecowitt.net. Expect it was a general WAN access issue. Who know why. Routers!
WU: IKNEBW2
Offline Gyvate
« Reply #2 on: April 12, 2021, 03:51:27 PM »
Your guess is correct !!  [tup] - see also https://www.wxforum.net/index.php?topic=40730.msg420959#msg420959
Confirmed by Ecowitt.
