Author Topic: Blank page showing after moving host - Solved_  (Read 255 times)
Offline Ian.
    • Chatteris Weather
« on: February 16, 2022, 10:49:42 AM »
Hi All,
I have moved from GoDaddy to Hostgator and copied all my files from one to the other, but if I enter https://www.chatteris.biz all I get is a blank page.
I did 'view page source' but it basically didn't have anything meaningful in it.
If all else fails, I will start from scratch as the site could do with a good 'weeding' of unused/redundant files, but it would be nice if it was a simple fix.
Cheers
« Last Edit: February 25, 2022, 12:33:00 PM by Ian. »
CWOP - DW3371
PWS - ICAMBRID16
Offline CNYWeather
    • CNYWeather
Re: Blank page showing after moving host
« Reply #1 on: February 16, 2022, 10:53:45 AM »
I just moved from GoDaddy also. Is your domain still at GoDaddy and if so/not, is it forwarded
to the new DNS address for your new host?
Tony
« Reply #2 on: February 16, 2022, 11:09:32 AM »
Looks like your new site is now running PHP 7.4.27.  Running check-fetch-times.php?show=versions shows the key scripts are up-to-date.
In top.php, you have
<?php require(&#39;/home/redpis/public_html/zbblock/zbblock.php&#39;); ?> and that is likely failing due to the changed path to your document root of  /home3/chattris/public_html  . the failing require() causes a fatal error when the required file is not found.
Offline Ian.
    • Chatteris Weather
« Reply #3 on: February 16, 2022, 11:50:33 AM »
Thanks Ken, that sorted it  [tup].
Now time to start tidying up and get wordpress to play nicely.
Thanks again all forchipping in  \:D/
CWOP - DW3371
PWS - ICAMBRID16
