Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
I don't recall the exact pinout (99.9% sure it's mentioned in a thread somewhere on wxforum). However, make sure the library you're using to communicate with the sensor is using Sensrion Bus and not I2C.This may help:https://github.com/HydroSense/sensirion
I'm not 100% sure why you would want to read a Davis T/H sensor with an Arduino? If I was doing that sort of thing, I'd choose a version of the SHT31 sensor that had a true I2C interface, something like:https://www.cqrobot.com/index.php?route=product/product&path=107&product_id=1121Or similar sensors from Adafruit etc. I guess the only issue is that this doesn't come with the Davis sensor's weatherproofing.
Keep in mind that the used sensor will likely have drifted from the original calibration.I'd honestly just go with a new I2C sensor.
Oh, that’s a problem, many thanks for the advice!
Just to fulfill my curiosity, I’ve to find out which pin is what, if I exchange sda with scl, do I make a mess or fry the sensor?
Nothing is guaranteed but you should be okay.
