So after rebooting to update to the latest firmware, here's the full log:
wnetd (03.02.2020 16:34:14): process started.
system (03.02.2020 16:34:14): start of logging process initiated.
wnetd (03.02.2020 16:34:14): send data thread started (pid:2303 tid:2305)
logger (03.02.2020 16:34:15): historical data loaded (34 records).
logger (03.02.2020 16:34:15): data logger (version 5.1c, build 13361) started.
logger (03.02.2020 16:34:17): connect station 0 (GW1000 via TCP/IP).
logger (03.02.2020 16:34:20): sensors are now providing data.
logger (03.02.2020 16:34:20): services started.
wnetd (03.02.2020 16:49:29): process received signal (11) and terminated: sendloop_LOOP_C < sendloop_LOOP_B < sendloop_LOOP_A < wnet_handle* < appendlog < wnet_handle <
logger (03.02.2020 16:49:30): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.02.2020 16:51:33): message above repeats 57 times.
test5m (03.02.2020 23:51:33): weathernet daemon stalled, will be restarted now.
wnetd (03.02.2020 16:51:33): process started.
wnetd (03.02.2020 16:51:33): send data thread started (pid:4634 tid:4636)
wnetd (03.02.2020 17:04:31): process received signal (11) and terminated: sendloop_LOOP_C < sendloop_LOOP_B < sendloop_LOOP_A < wnet_handle* < appendlog < wnet_handle <
logger (03.02.2020 17:04:33): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.02.2020 17:05:51): message above repeats 33 times.
test5m (04.02.2020 00:05:56): weathernet daemon stalled, will be restarted now.
wnetd (03.02.2020 17:05:56): process started.
wnetd (03.02.2020 17:05:56): send data thread started (pid:6039 tid:6041)
Platform: TL-MR3020 (no USB hub)
RAM: 29364 kB total, 2416 kB free (91% used)
SW Version: Meteobridge 4.3 (Feb 1 2020, build 13361), FW 1.4
Uptime: 0 hours, 37 minutes Buffer: 3 items (0%)
As a side note, ever since I got the MB connected to a GW1000 and configured months ago, I've never been able to get back into the "Weather Station" page. When I click on the tab, it gives the following error:
The CGI process did not produce any response
