Mark,
When I had trouble with the V 1.0 Module, I went back to the V1.15 and Rapid Fire until I had a plan of attack on getting V 1.0 working properly.
Based on your input, here's what I've done:
1. Deleted all Modules using the WL Manage Modules option.
2. Physically deleted the Module programs/dlls from the Weatherlink\Expansion Module directory.
3. Closed and restarted WL
4. Verified that WL Manage Modules was not finding anything by trying to Add a Module. None available, as the Expansion Module directory is empty.
5. Verified that WU was not available in through the Setup>Internet Settings menu.
6. Downloaded and ran the V 1.0 .exe file to install the V 1.0 files in the Expansion Modules directory.
7. Performed the Setup>Internet Setting to create a Profile for the WU upload.
8. Closed and restarted WL
The first scheduled time, the Module performed the download of data from the Vantage Pro 2, and then aborted without connecting to the internet to upload the data.
The second scheduled time, the Module performed the entire function, including the upload of 7 days data to WU. So it appeard the all is working as it should be.
All that is remaining is to reduce the amount of archive data from 7 days to 1 day (which will cover the Computer downtime) and I should be in business.
Thank you ever so much for the help.
Success
George
