Author Topic: Erroneous graphs on WU  (Read 4602 times)
Offline SoMDWx
    • Southern Maryland Weather
« on: July 13, 2009, 10:42:12 PM »
All,
  I just had a 62 mph wind gust show up in error on VWS. I have corrected the VWS bin files and my own almanac entries are coorect. However, WU still shows the bad values in their graphs and data..
I am really beggining to wonder if I should go to something else to display historical data. comment? suggetsions?
JIm
Offline d_l
  • Slide Mtn - Mt Rose
Re: Erroneous graphs on WU
« Reply #1 on: July 13, 2009, 10:53:22 PM »
You can delete the entire data set for that time interval from WU if you wish.  You might have to enable the Entry Deletion "button" at the bottom of your daily data page before you can delete any entries.  I've had instances of -99% humidity before when my Meteohub was temporarily halted that I had to delete.
--Dave--
Offline SoMDWx
« Reply #2 on: July 15, 2009, 01:42:32 PM »
where is this done?
jim
Offline TorH
    • Været på Fauske
« Reply #3 on: July 15, 2009, 01:57:21 PM »
At the bottom of your daily history page, when your logged in, is that buttom.
Then you can the delete the total entry of that point, not just the wind gust. That's how i understand it.
Davis Vantage PRO2 wireless
VWS V14.00 p103, WD ver.10.37N, WL 5.8.2, VVP.
WeatherFlash
DW1549
WeatherUnderground: INORDLAN14
Location: Fauske, Northern Norway. N 67°15'41", E 15°24'41"
http://bjornli.net
Offline d_l
« Reply #4 on: July 15, 2009, 02:51:48 PM »
I'm not sure if you delete some erroneous data intervals for a day in the past if the historical records are ever updated to reflect that deleteion.  I corrected my annual Weatherlink rainfall amounts in early July.  Somehow the slight change was registered as a slight rainfall on that day on WU.  Many days later I deleted the WU interval records with the bogus rainfall.  The WU monthly and weekly summaries haven't yet reflected the deletion.
I do know that if you delete the bad data on the day it happens, that the monthly and weekly summaries are corrected.
--Dave--
Offline SoMDWx
« Reply #5 on: July 15, 2009, 04:26:09 PM »
I don't see any buttons that modify/delete history data....
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KMDLEXIN4
Jim
Offline TorH
    • Været på Fauske
« Reply #6 on: July 15, 2009, 05:09:16 PM »
You must be logged into yor WU account, then it shall be there beside the "Comma Delimited File" buttom.
So it's here.
Jim
WeatherFlash
DW1549
http://bjornli.net
Offline SoMDWx
« Reply #7 on: July 15, 2009, 05:20:03 PM »
Found it! Thanks. Now I will go back and edit the rest.  =D>  =D>
Jim
« Last Edit: July 15, 2009, 05:26:09 PM by SoMDWx »
Offline TorH
    • Været på Fauske
« Reply #8 on: July 15, 2009, 05:26:22 PM »
Saw it should be July 11. but i didn't see the specific file (time) so it maybe therefore i think. I thought it got it's records from those files  :?
Yes, but you cannot edit it...
WeatherFlash
DW1549
http://bjornli.net
Offline SoMDWx
« Reply #9 on: July 15, 2009, 05:29:10 PM »
See post above you... found it! Thanks... stumbled on it and deleted the entry... Seemed to propagate throught the system except the graphs.
Jim
Offline d_l
« Reply #10 on: July 15, 2009, 07:57:57 PM »
It may take a while for a deleted entry to propagate through the historical records and graphs. ... or at least I hope my deletions eventually do.  WU seems to run several days behind when you make a major change, add a new station, etc.
--Dave--
Offline TorH
    • Været på Fauske
« Reply #11 on: July 16, 2009, 04:37:05 AM »
Great  :grin: Then it might adjust the graphs to in a bit, if it is like d_l mentioned.
Jim
WeatherFlash
DW1549
http://bjornli.net
