Weather Software > WeeWX Software
installed weewx
alpha13:
Aid (windows10)
I haven't just installed WEEWX. When I run (weectl station create). causes the following message:
(weewx-venv) c:\virtual\weewx-venv\Scripts>weectl station create
Traceback (most recent call last):
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "c:\virtual\weewx-venv\Scripts\weectl.exe\__main__.py", line 7, in <module>
File "C:\virtual\weewx-venv\Lib\site-packages\weectl.py", line 58, in main
module = importlib.import_module(f'weectllib.{subcommand}_cmd')
File "C:\Users\Fran\AppData\Local\Programs\Python\Python312\Lib\importlib\__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "C:\virtual\weewx-venv\Lib\site-packages\weectllib\station_cmd.py", line 12, in <module>
import weectllib.station_actions
File "C:\virtual\weewx-venv\Lib\site-packages\weectllib\station_actions.py", line 9, in <module>
import grp
ModuleNotFoundError: No module named 'grp'
N0NB:
To my knowledge WeeWX is only supported on Linux based systems. You may wish to confirm that on the user support forum: https://groups.google.com/g/weewx-user
gszlag:
You may find this link helpful https://weewx.com/docs/5.0/
alpha13:
--- Quote from: gszlag on March 12, 2024, 07:31:30 AM ---You may find this link helpful https://weewx.com/docs/5.0/
--- End quote ---
It's the first thing I did
vinceskahan:
https://docs.python.org/3/library/grp.html says not available on windows.
Only thing I can suggest is building in Docker or in a virtual machine running Linux. It's been enough years that I have no idea if you could possibly install cygwin and run python in there, but either way it would be a hack at best. The Docker or VM path is more unixy.
[#] Next page
