Author Topic: Weatherunderground  (Read 3514 times)
Offline mtman1849
    • Southmont Highrock Lake
Weatherunderground
« on: January 23, 2009, 12:07:50 PM »
when I set up my weather station some years ago and was making my weather under ground set up I messed up on the location on the goggle map part  I have since fixed it but now it show two locations for my weather station on the map the orginal goof up and the correct one does anyone now how to remove the goof up from the goggle map
thanks
Offline tomcj2
    • CanbyWeather
Re: Weatherunderground
« Reply #1 on: January 23, 2009, 01:06:04 PM »
What is your WU Station ID# ?
Davis VP2 (6163), WL 5.9.0..  VWS 14.01 p25, Panasonic HM371A camera. WU & W4U KORCANBY3, CoCoRaHS OR-CC-27
    • Watts Bar Weather
« Reply #2 on: January 23, 2009, 01:55:40 PM »
If you go to the "my stations" page does it show two stations?
You should send them an email and tell which one you want to keep, and they'll delete the second one.
I wish they would add a delete button next to the add and edit buttons on the "my stations" page.
Offline mtman1849
« Reply #3 on: January 23, 2009, 04:32:41 PM »
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KNCLEXIN6  this is the link to my station and in my stations it is the only one listed
Offline tomcj2
    • CanbyWeather
« Reply #4 on: January 23, 2009, 04:46:32 PM »
The map is showing 2 ID's : MC9811, and KNCLEX1NG.  They are showing different data, and neither is showing hardware or software.  Why?
Offline mtman1849
« Reply #5 on: January 23, 2009, 04:57:14 PM »
View Interactive WunderMap
About This PWS:
 Lat: N 35 ° 40 ' 39 '' ( 35.678 ° )
Lon: W 80 ° 14 ' 43 '' ( -80.246 ° )
Elevation (ft): 798
Hardware: LA CROSSE 2315
Weather Station Software: WUHU21623XXSP
On the google map the actual location is the southern most location
    • Watts Bar Weather
« Reply #6 on: January 23, 2009, 05:59:28 PM »
I see the two stations, and I've seen your webpage.  The other (MC9811) looks like an airport or something.  It's not rapidfire and it's listed as APRSWXNET.  It's 1 to 2 degrees different.
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=MC9811
I donno.  You should email WU.
When I first started, I had 4 stations listed before I got it the way I wanted it.  I sure wish there was a delete button besides the add and edit buttons.  The edit function seems to lock up a lot, too.   ](*,)
Anyways, I emailed them and they fixed it so that now I only have two stations (because I have two stations).   =D>
Hope this helps.
If it went smooth all the time, it wouldn't be any fun!
Offline Mark / Ohio
  • Live from Mars!
    • Fairfield County Weather
« Reply #7 on: January 23, 2009, 08:05:43 PM »
I'm thinking it took at least an hour to a day after tweaking my location for the old one to disappear of the map.  The data seems to be stored in more then one place and it takes a little time for all the computers to update.
Offline tomcj2
    • CanbyWeather
« Reply #8 on: February 28, 2009, 04:12:45 AM »
mtman1849,
I see only 1 station now.  What was the remedy?
