Author Topic: Cumulus update 4.5.0  (Read 1095 times)
Offline OldAlaskaGuy
  • Alaska, The Last American Frontier
  • An old Alaska guy living in an insane world.
« on: May 26, 2025, 03:26:56 PM »
I am attempting to install the latest version upgrading from 4.4.5. Where are the instructions on how to upgrade located? I have downloaded the installation files.
Ambient Weather: WS-2902, IP Observer v4.6.2
Ecowitt: GW1000B: v1.7.8, GW1200B v1.3.8, GW3000B v1.0.9
Sending weather data to, Ambient CWOP, Ambient Weather, AWEKAS, Ecowitt, PWS Weather, Weathercloud, Wunderground, MADIS, and APRS
CumulusMX dashboard. V4.5.2b4505
Ambient Weather  https://ambientweather.net/dashboard/b71db9ae6b3ebd3a3db1864a6b9eeb2b
Ecowitt https://www.ecowitt.net/home/share?authorize=SEJRPK
AEKAS https://stationsweb.awekas.at/home?id=20470
Offline PaulMy
Re: Cumulus update 4.5.0
« Reply #1 on: May 26, 2025, 03:49:57 PM »
With CMX stopped, just copy all unzipped files and folders and paste in your working \CumulusMX folder, accept to replace all files.
Restart CMX.
p.s. Before upgrading I always take a full copy of the live \CumulusMX\ folder and place it in a CMX-backups folder - i.e. \CumulusMX-backups\v4.4.5-b4088\CumulusMX\ just in case!
Enjoy,
« Reply #2 on: May 26, 2025, 05:08:45 PM »
Thank you for the help. Updated without issues. Some minor bugs, reported at Cumulus. Can not change the shape of the alarm indicators in the AI version.
Offline Wooks61
  • Aerospace Engineer Avionics (Ret.)
« Reply #3 on: May 26, 2025, 06:22:57 PM »
I use this method
Stop CumulusMX
I create a new directory (e.g \CumulusMX_V_4_4_5) and copy the current MX directory (e.g. \Cumulus_MX) into it.
Then copy the downloaded  updated release.zip into the \Cumulus_MX directory.
Run InstallCMX and follow the prompts.
Start CumulusMX
See  https://cumuluswiki.org/a/Updating_MX_to_new_version#Installer_Option
Offline broadstairs
« Reply #4 on: May 27, 2025, 03:16:10 AM »
That alarm shape issue does not occur on my install of this new version. As explained in your other thread on the CumulusMX forum.
Stuart
« Reply #5 on: May 27, 2025, 02:52:12 PM »
Stuart
I have a second instance of CulumusMX 4.5.0 running (concurrently and in real time) on another computer where I can change the shapes. I copied over the entire CumulusMX folder to the problematic installation (I did not overwrite and both are getting data from the same GW3000) and it did not solve the issue.
« Last Edit: May 27, 2025, 03:15:15 PM by OldAlaskaGuy »
Offline mcrossley
    • Wilmslow Astro
« Reply #6 on: May 27, 2025, 03:22:16 PM »
Clear your browser cache for the failing install site.
« Reply #7 on: May 27, 2025, 03:56:47 PM »
No change. It's not a big issue. Everything else seems to be working. I would think by importing a working copy of CumulusMX it should work the same.
« Last Edit: May 27, 2025, 03:59:24 PM by OldAlaskaGuy »
