Author Topic: Connecting hp2560 to CumulusMX  (Read 1442 times)
Offline Billyram
    • The Rapids
« on: May 23, 2025, 09:10:55 AM »
Any suggestions ! WU shows I'm running easyweatherpro v5.1.6
« Last Edit: May 23, 2025, 04:36:39 PM by Billyram »
HP2560 Console
WS5000 Sensor Array
WH40H Rainfall Sensor
WH57 Lightning Detection
CumulusMX
https://www.ecowitt.net/home/index?id=253478
https://www.wunderground.com/dashboard/pws/KSCNORTH351
Online PaulMy
Re: Connecting hp2560 to CumulusMX
« Reply #1 on: May 23, 2025, 11:22:03 AM »
If starting CumulusMX for the first time the startup DOS screen will give you a URL to enter in a browser and to run the Wizard - i.e. localhost:8998/wizard.html
Enter that and follow the Wizard's setting prompts, including the station type, etc.  When that is completed you may need to stop CumulusMX, and then restart.  You can then go through the other settings to suit.
If you have already run CumulusMX before, then go through the Station settings to suit your station type.
Enjoy,
Offline box
« Reply #2 on: May 24, 2025, 06:15:37 AM »
Hello
Just backing up a little, what stage are you at?
Have you actually installed CMX yet?
https://cumuluswiki.org/a/MX_on_Windows_OS
The first time you run it as Paul says above it will report an IP address 192.168.1.xy:8998 which you can insert into a browser to talk to CMX. The first time you do that it will initiate a wizard to guide you through the process and create a file called cumulus.ini to store all your settings.
Note that the installation files do not include a cumulus.ini file, you have to run the program once to create it
You can run the settings wizard from the main page every time you need to change anything, if all goes wrong simply delete the cumulus.ini file and start again
The wiki link is pretty well written, read through it first
If you are installing on Linux
https://cumuluswiki.org/a/MX_on_Linux
Once installed the settings process is the same
Hope this helps
Offline Billyram
    • The Rapids
« Reply #3 on: May 25, 2025, 04:10:12 PM »
I've got the files loaded and unzipped but can't first time start. First run
« Last Edit: May 25, 2025, 04:41:55 PM by Billyram »
HP2560 Console
WS5000 Sensor Array
CumulusMX
Online PaulMy
« Reply #4 on: May 25, 2025, 05:50:09 PM »
Can you tell us what you have done, what displays, etc.?
Enjoy,
Offline Billyram
    • The Rapids
« Reply #5 on: May 25, 2025, 07:27:20 PM »
I have the cumulus mxdist4088 file in my computer. When I get to the first run page it won't let me open.
« Last Edit: May 25, 2025, 07:40:09 PM by Billyram »
HP2560 Console
WS5000 Sensor Array
CumulusMX
Offline R.Sidetrack
« Reply #6 on: May 25, 2025, 08:26:48 PM »
We can assume you are likely using Windows.
But "it won't let me open" doesn't help much.  You could type the entire error message into your post, along with what filename you were trying to open.
Or capture the screen and post the screenshot here.
Graham
--- Variety of 'discrete' Ecowitt devices; CumulusMX on Raspberry Pi4 ---
Online PaulMy
« Reply #7 on: May 25, 2025, 08:40:07 PM »
Sorry, I don't understand what 'the first run page" is.
Ok, basics:
1. You have unzipped the CumulusMX download and the unzipped files are all in a folder something like C:\CumulusMX, is that correct?
2. You then go to C:\CumulusMX\CumulusMX.exe file and right click on it, and select Run as Administrator, is that correct?
3. You will now see a DOS type screen that displays startup process, and ends with something like the following
Cumulus MX v.4.4.5 build 4088
Working Dir: C:\KomokaWeather\CumulusMXwll\
Delaying start for 10 seconds
Start-up delay complete, continuing...
Cumulus running at: http://localhost:8999/
                    http://10.0.0.75:8999/
  Open the admin interface by entering one of the above URLs into a web browser.
is that correct?
Enjoy,
Offline Billyram
    • The Rapids
« Reply #8 on: May 26, 2025, 09:00:09 AM »
Unzipped cumulusmx is in windows c. all files are showing and I can open them up. I can open first time setup wizard and look at dashboard but need to get my station in it some how.
« Last Edit: May 26, 2025, 09:03:18 AM by Billyram »
HP2560 Console
WS5000 Sensor Array
CumulusMX
Offline R.Sidetrack
« Reply #9 on: May 26, 2025, 09:09:37 AM »
Once you are at the CumulusMX 'Dashboard', click on Settings, then Config Wizard.
You should get something like my screenshot. Work your way through it, step by step.
Graham
Offline Billyram
    • The Rapids
« Reply #10 on: May 26, 2025, 09:36:13 AM »
I believe I don't have cumulus running yet. I can click on config wizard and nothing happens.
HP2560 Console
WS5000 Sensor Array
CumulusMX
Online PaulMy
« Reply #11 on: May 26, 2025, 09:47:44 AM »
Ok, still at basics...
Have you done item 2?
Do you then get the DOS type screen as per attached?
If so then what did you do?
Enjoy,
Offline Billyram
    • The Rapids
« Reply #12 on: May 26, 2025, 10:26:42 AM »
I believe this is over my head. I'm going to Waite till I can get some help. Thank you for your Patience.
HP2560 Console
WS5000 Sensor Array
CumulusMX
Offline Billyram
    • The Rapids
« Reply #14 on: July 06, 2025, 07:39:40 AM »
Yes I got CumulusMX running and my WeatherLink data transferd to CumulusMX. The problem I was having I overlooked not having .net8 in my computer. I'm really enjoying CumulusMX.
HP2560 Console
WS5000 Sensor Array
CumulusMX
Offline Wooks61
  • Aerospace Engineer Avionics (Ret.)
« Reply #15 on: July 06, 2025, 08:05:26 AM »
 :grin: =D> \:D/
