Author Topic: Force Nightly NOAA AND Monthly Report?  (Read 1354 times)
Offline scottct1
    • Newington, CT Weather
« on: March 09, 2025, 07:06:08 PM »
Just wondering...
My WD display machine went down last night and I did not get to fix it until this morning.
On my website (I use the Saratoga template) if I click on Status it shows "Weather-Display NOAA report" and the
"Weather-Display Month report"  being Not Current.  Normally this is generated and updated at 12:08 AM by Weather Display.
I looked through Weather Display and can't find a way to have it generate these two things so I don't have to sit for a day for these two things showing "Not Current"  is there a way to force these things in WD?
Scott - NewingtonWeather.COM - Newington, Connecticut's Weather Source!
Davis Vantage Pro 2 Plus - WeatherFlow Tempest for Lightning - Weather-Display Software
Offline NorCal_Dan
    • Traveling RV Wx
Re: Force Nightly NOAA AND Monthly Report?
« Reply #1 on: March 10, 2025, 07:08:17 AM »
You can manually tell WD to create these files but you will need to ftp them manually to your website.
Offline weatherdoc
    • Weather Doc's Weather
« Reply #2 on: March 10, 2025, 08:20:26 AM »
Here's step-by-step instructions in WD:
- Go to View → Averages/Extremes NOAA Style Reports
- Recreate the reports you require for the month you are correcting by selecting the tab Averages/Extremes
- Select the date to calculate and click Update whole month now
- Update the Monthly Data webpage file (March2025.htm) by selecting the tab Recreate the Web Av/Ext Page
-Click Reset the web page averages/extreme button
-Click OK to exit the window
-Update the Climate Data webpage (climatedataout.html) by selecting the tab Detailed Climate Report
-Click Update month now button to fill-in the missing days
-FTP the March2025.htm file from C:\wdisplay\webfiles to the server
-FTP the climatedataout.html file from C:\wdisplay\webfiles to the server
